R50/53 Jb-weld on tranny case??
Old Nov 13, 2013 | 10:06 AM
PawnShopMike's Avatar
PawnShopMike
Never had an opportunity to introduced myself the this forum
I bought my first mini a week ago .... Yesterday clutch goes out!! So drop it off
At big apple auto repair in Marietta , the tech sends me THIS PIC!!!
Old Nov 13, 2013 | 10:15 AM
Swimbaxter's Avatar
Swimbaxter
Wow, that really looks like #$%#$. With that said, did that have anything to do with the clutch failure?
Old Nov 13, 2013 | 10:24 AM
PawnShopMike
Tech said it allowed for "play" & said he drop tranny & see what eles is going on
The pedal became sorta hard to push & with 100miles now when you ouch in the clutch it's sounded like a bottom end knocking .... & clutch was 100% not working ((as in I couldn't disengage) ..... But I crank it in first & speed shift to 3rd then 5th to get it to the repair shop
Old Nov 13, 2013 | 10:25 AM
PawnShopMike
Mind you once in gear ..... Like in 5th o. The highway she feel perfectly normal
Old Nov 13, 2013 | 10:28 AM
ZippyNH's Avatar
ZippyNH
Get your money back.....
Old Nov 13, 2013 | 10:31 AM
Swimbaxter's Avatar
Swimbaxter
+1 on this. You clearly inherited a problem that someone took a major shortcut to fix.
Old Nov 13, 2013 | 12:44 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I also would try to get your money back.. Ive seen a few MINIs now with the 5 speed transmissions where the case has been welded from some previous problem.. So there must be something that is a known problem.. I think the 5 speed trans. is the Midland type that have these problems.. But either way I wouldn't leave the JB cold weld on it.. I would either get it welded or find a new case or transmission..
Old Nov 13, 2013 | 01:19 PM
PawnShopMike
Does the "s" 6speed work in NON "s"
Old Nov 13, 2013 | 01:34 PM
ZippyNH's Avatar
ZippyNH
I think it is a similar amount of work as changing a CVT to a 6 speed...
New tranny, different cv joints, different flywheel, starter (I think)....and you will lose the cruise...and gearing is much less "sporty" due to less hp of the base Cooper...so doubt you would find the swap makes $$$ sense....
Old Nov 13, 2013 | 01:37 PM
miles_miles7's Avatar
miles_miles7
Yes it does. I sold some parts to a gentleman in Los Angeles for the conversion and help him with any question he had with the conversion.
If ever you need 6 speed s tranny i'm selling my spare one.
PsychoRallye
21
Feb 17, 2019 06:08 AM
NorthWestEuro
Oct 20, 2016 06:41 AM
minimofo
Dec 26, 2015 12:03 PM
mni928
Nov 9, 2015 07:38 PM
bahman
Sep 30, 2015 01:59 PM
