R50/53 Stoker's Rebuild Thread
Old Sep 9, 2013 | 04:12 PM
Stoker's Avatar
Stoker
As an "Homage" to GreekDrifter i am starting my own "Rebuild" thread of the identical car to his (Purely by coincidence. It's not like i went looking for exactly the same car)
Anyway.. A bit of background on the car, I'm lucky enough to have a "mini shop" five miles from my house "Custom Mini Shop" in Fresno.. So, I take the car in for Steve to have a look at, It's always worthwhile getting a second opinion when buying a used mini. By Chance he's already worked on the car for the previous owner.. so, long story cut short, most of the usual maintenance requirements for a car this age had already been taken care of.. "Brilliant!!" I shouted "but you do need powerflex bushings" he said in response.. Thats next week... I'm not the grease-monkey like GreekDrifter, so Steve is gonna put those on... In the meantime, i'm gonna put the stuff, pictured below, on the car..
The upgrades that have been performed:
Sprintex Super Charger W/69mm Pulley.
Thumper TPR-2 Cylinder Head.
Thumper NS-1 Cam.
Thumper Ported Intake manifold.
Boria performance exhaust. (Sounds brilliant)
M7 CAI.
GP I/C + OEM Diverter plate.
Bosch 550cc injectors. (ECU Flashed by Bytetronic)
Screamin Deamon coil pack, W/New spark plug cables.
Wide Band. (flashy lights ") for tuning..
Spec stage 2 clutch (Feel's amazing!! we'll see if it lasts.. The "Rattle" from the tranny takes some getting used to… )
Phantom Grip LSD (It's a trip how it just "works")
M7 Header heat shield..
M7 Front strut brace, Subframe brace and Rear Pillar brace.
Megan 32 point adjustable coilovers (They Rock!!)
Stop tech rotors all-round.
Powerflex engine mount Bushings, on new OME Engine mounts. (Less vibration than aftermarket, while still retaining stiffness)
Hotchkiss 19mm Swaybar. (Still in the middle position)
Helix Adjustable Rear Control Arm's (I had the alignment guy put them on, couldn't do it myself using jack stands)
Falcon 215/40 Super sticky tires On New Rims..
Alignment!!
Short shifter. (Huge difference)
Craven speed Gearknob. (Drilled and tapped for set screws to fit my random short shifter)
Craven speed hand brake.
Craven speed Shift well cover. First i put in the black one.. now, i've found a chrome one..
Craven speed Smartphone Mount Pro Series.. (Very cool)
Parrot Asteroid Classic Stereo. (I had the parrot harness rewired to make it fit)
Euro Parcel tray. (Useful)
Redid the entire interior of the car w/Chrome trim.
New peddles from the 2006 MCS (they look a lot nicer than the "Toy car peddles" on the 2002)
M7 Grills Front and back. (Wicked Cool!!)
Wet Okole Seat covers that match the car perfectly..
Black "Joey" mod headlights. Rear Alecantra lights.
Full exterior blackout, with the exception of "Black Jack" door handle covers.
Items Replaced during the trip to the menders:
Engine vacuum valve and tubing (The reason For the p1477 code)
Lower top engine mount with OEM Part.
New Spark plugs NGK BKR8EIX.
Front control arm bushings, Polyurethane with power flex inserts.
Front sway bar bushings replaced with power flex poly bushings.
The drivers side horn that was missing..
Gear shift cables (The old one's were just plain worn out)
Brake master cylinder.
Clutch slave cylinder.
Stainless steel brake lines.
New Battery..
All the "Mal Practice" bolts and screws that previous owners used in a pinch.
No Codes!!
Attached Thumbnails Stoker's Rebuild Thread-img_0772.jpg   Stoker's Rebuild Thread-new-bibs-and-bobs.jpg
Old Sep 9, 2013 | 04:30 PM
Stoker's Avatar
Stoker
Spark plug wire's were upgraded too..
Old Sep 9, 2013 | 04:47 PM
Stoker's Avatar
Stoker
Steve is trying out the Spintex SC on his mini first, so i may get one of those, you never know.. one thing i do know, it's either a rebuild on the current SC or a new one.. since, with the new pulley... "it ain't gonna last"
Old Sep 9, 2013 | 07:40 PM
GreekDrifter91's Avatar
GreekDrifter91
Very cool! I'm glad to have inspired you to make a build thread. i love to make notes like a journal and take LOTS of pics. its cool to see progress. i do go through my build threads every so often and look how far i have come with things, its very neat. and i make sure to take lots of pics because it helps other people out too!.... and threads are just worthless with out pics
Old Sep 9, 2013 | 08:58 PM
Stoker's Avatar
Stoker
I've PB Blastered My Pinch Bolts For The Last Three Days ")
Sorry to bring back a painful memory.. hopefully they come out clean.. I'll let you know, i'm starting tomorrow afternoon..
Old Sep 10, 2013 | 12:48 AM
Kahnfucious's Avatar
Kahnfucious
First Steve is awesome!! You are incredibly lucky to be near his shop.
Second if it's a California car - I wouldn't worry about the pinch bolts too much...mine came out clean and super easy. Despite the fact that the car had spent a year or so over it's life in the northeast and is now back in the northeast.
LCA bushings are a must and Steve will sort you out there.
Good luck and welcome!
Old Nov 12, 2013 | 01:40 PM
Stoker's Avatar
Stoker
Mods So Far
See Last Post..
Old Nov 12, 2013 | 01:45 PM
Stoker's Avatar
Stoker
Mods To Do, Hopefully This Month.
Sprintex SC CARB Edition W/64 mm Pulley (Sitting In My Office)
Thumper TPR-2 Cylinder head With Cam And Cam Sprocket With Ported IM (Arrives Dec 4)
GP Intercooler With That Fancy diverter...
New Chain. New Belt.
"Straight Through" Exhaust With Battery well "Delete".. Not Sure Which One To Get Yet..
New Oil Pump.
550 Injectors.
Air/Fuel Mix Sensor.
Tune By Bytetronic..
Wet Okole seat Covers..
Old Nov 12, 2013 | 02:12 PM
Stoker's Avatar
Stoker
Turns Out Theres One Dyno Shop In Fresno. So… Check Back The 2nd Week In December!! I'll Put Up Some Numbers.. And Some Pics, Once The Sprintex Is On...
Old Nov 12, 2013 | 07:26 PM
Tab32's Avatar
Tab32
So much want! Interested to see the Bytetronic tune!
Old Nov 13, 2013 | 01:46 PM
Stoker's Avatar
Stoker
Me Too ")
Old Nov 13, 2013 | 02:09 PM
Stoker's Avatar
Stoker
I know, I haven't put up many pics..
Since i'm following Greekdrifter's build thread... It's crazy how my pics look exactly the same as his…. With one exception I Managed to get the washers on the upper engine Powerflex bushing…. I used a spring spreader to push the arms apart on the "Bridge" mount to the lower bearing… Plus Two Small "G" Clamps To Push The Washers Together… Lots of trial and error till i managed to get about 3 millimeters of the top and bottom arms onto the washers… Then a rubber mallet and a 2 by 4 helped me get it on the rest Of the way…By the end, i wasn't in the mood to take Pictures ")
But, you can see the top washer in the pic As-well as the top of the Megan Coilover…
2nd Pic Is Real World Of The Cravenspeed Stuff
Old Nov 13, 2013 | 02:19 PM
Stoker's Avatar
Stoker
One thing i forgot, I put a cool set of light's on the car, Found them on amazon
Here's The Link:
Mini Cooper Crystal Black Halo Projector Headlights+Clear Tail Lights Mini Cooper Crystal Black Halo Projector Headlights+Clear Tail Lights
Couple Of Real World Pics.. Plasidip Rocks!!
Attached Thumbnails Stoker's Rebuild Thread-photo-3.jpg   Stoker's Rebuild Thread-light.jpg
Old Nov 13, 2013 | 02:37 PM
Tab32's Avatar
Tab32
How do you like the headlamps? Ive been looking into maybe getting them
Old Nov 13, 2013 | 02:46 PM
Stoker's Avatar
Stoker
They work well, Bit awkward to adjust… Install took ten mins For each light..
i just tapped the wire's that were already on the lights for the LED Halo.. The Halo's rock!! they look slightly out of place on a mini, which suits me!!
Old Nov 13, 2013 | 03:03 PM
Tab32's Avatar
Tab32
Awesome to hear. I think i'll get the chrome color matched dark silver and put em on.
Old Nov 13, 2013 | 03:05 PM
Stoker's Avatar
Stoker
Those rock!! They're like brushed stainless steel right?
Old Nov 13, 2013 | 03:12 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Dont forget to join the Sprintex Owners Thread, I will put your name on the list once its installed.
Keeping an eye on your progress...
Old Nov 13, 2013 | 03:17 PM
Stoker's Avatar
Stoker
Can't Wait!!…. Now that i've blasted out the dosh… (Spent The Money )
I wanna get it done
Old Nov 13, 2013 | 04:34 PM
Stoker's Avatar
Stoker
I know, i am spending a lot of money….
If i had wanted too i could have bought a Lotus or a Porsche… Not that there's anything wrong with those car's, I just remember, when i was kid i had three mini's in a row…. then a 45 ford pop (see pic) a couple of jags.. Then, after i moved to the States, 3 Toyota's over the last 29 Years… The Mini's were the most "fun" i've ever had in a car…
So, I bought my daughter A 2008 MCS JCW "aero kit". Since she's had it, I've wanted to drive it more than her!! Of course, she wouldn't let me use It.. Did bring back a lot of memories though, Mini's are a blast!! couldn't resist the deal i got on the 2002.. It was cheap enough that i knew i could spend a bunch, yet still come out, having spent far less than it would cost to buy that 2007 lotus exeige!! besides that, my Mini will be "just the way i want it"…. Now, that lotus should be beware ") It will get its butt kicked..
One thing though, i bought this Mini a week before i saw Walen's GP... Which i would have bought in a new york second!! As Far as i know it's still for sale!! someone should jump on that!!
Having said that (after i fixed up the Pop) I've a become a bit of a purest when it come's to classic cars… I wouldn't mess with a GP… So, i wouldn't be having as much fun as i'm having now!!
Attached Thumbnails Stoker's Rebuild Thread-531963_10200466290195094_234460108_n.jpg
Old Nov 13, 2013 | 05:29 PM
SpiderKnight's Avatar
SpiderKnight
Thanks for sharing. Hey, love the shift dust cover
I noticed you are using a Parrot Asteroid, how do you like it? I have one. For a while, I had the UK software version and the British accented voice seemed so appropriate
Old Nov 13, 2013 | 06:00 PM
Stoker's Avatar
Stoker
It Rocks!! It can categorize any size SD Card.. Currently I have a 32 gig card in the Asteroid.. That means i can listen to Everything I Have Ever Bought.. Directly from the stereo itself!! Crazy!!! You Just Say "Rolling Stones Satisfaction" and your off to the races….
It's perfectly capable of becoming an internet device.. Maps, GPS, Email, Facebook… The Whole Bit (Android OS) but i couldn't see the point (I have an iPhone) so i didn't bother with that part of it. plus, you need to buy the monthly plan with your provider..
But, bluetooth Is seamless.. You get in the car, thats It, bluetooth link up without any fiddling around..
It's also got four usb ports which is useful for charging… (Stuck em all in the Glove Box, besides the one for the Phone)
And yes, The Brit accent was a nice surprise!! People think i did it on purpose ")
Old Nov 13, 2013 | 06:50 PM
GreekDrifter91
Attachment 84163
Attachment 84164
i must put the washer in now! for real they are starting to tear at the center...
how do you like the coilovers? i was going to get them but choose koni's ands swifts instead.
Old Nov 13, 2013 | 07:02 PM
Stoker's Avatar
Stoker
Love Em!! I can do a 90 @ 70MPH Thats as fast as I'm willing to go!!... Edit: i can accelerate through a 90 From 45 To 70 in second, without worrying about hitting the Curb… (On a dark night in my neighborhood )
Get a couple of small g clamps, put them at the back of the washer's... Grease The heck out of the washer's, put all the bolts in the mount. hand tighten the bolts…
reverse a spring tensioner, put it between the two "arms"… its a struggle, but it's worth it
Powerflex should make them 2 millimeters thiner. Unless Somebody over there thought it would be a good joke!! It's a very tight fit...
Old Nov 13, 2013 | 07:04 PM
piston's Avatar
piston
Have fun and good luck.
Cheers and hope it doesnt go boom.
