R50/53 Looks like MINI is finally covering the ps pump failures for 13years or 150k miles.
#126
If the pump is out you will know it! At low speed it's almost impossible to turn. Also the pump runs all the time when the engine is running, so you can hear it whining. A worn pump whines MUCH louder than a new one.
#127
#128
Thanks for the tip! I will check the fluid level when I get back too to see if thats ok. Maybe it just is naturally heavier than other cars I've tried, including a 2007 MINI...
#130
#131
My understanding is that cars made after 03/05 are not covered.
Can you give it a good bath and try to see the leak?
#132
#134
I parked my wife's 2005 MINI Cooper S (hardtop) in the garage after grocery shopping with her and my daughter. I took some items into the house and when I walked back in the garage, smoke was bellowing from under the hood. My wife was pulling my 2.5 year old daughter out of her car seat. I popped the hood, found smoke pouring from between the head and the firewall. I looked down further and found that there was a small flame down by the steering rack. I got the car out of the garage as fast as possible and ran for the fire extinguisher and put out the flame. I've read that there are quite a few cases of this happening. Is it the same root cause as the steering pump failure or is it different? Also, is there an exact VIN range anywhere? I didn't see it in the thread. We are the original owners of the MINI and got no such letter (we have moved 2x since we bought it 10 years ago.) It is a Jan or Feb 2005 build. The car only has 73k miles.
Any help is appreciated. Thanks,
Quentin
Quentin
#135
#136
I just had my P/S recall performed by MINI and they told me it was a $2,000 job. He then hit me with "you also need blah, blah, blah, blah, blah... (you get the idea) done", to the tune of about $1,500 more. So I told them to just do the recall work and I would see about doing the rest later. Thanks to NAM I looked up what he wanted to do and a couple of $1 clamps will save me over $500 on just one of the repairs.
#138
To their credit, MINI is stepping up and taking care of everything. The fire happened over a month ago and they are just now starting the repair, though. The weather was probably a week of delay, but I'm anxious to get this all over and done.
#139
FYI... Not all minis in that letter are covered... seemed like a blanket letter to all owners
I have a 2005 MCS JCW.. 41K miles and change...
so well under the mileage - check
within the 13 year coverage time - check
Went to the dealer because my power steering fan sounds like metal on metal.. maybe bearings going out... so they checked my vehicle in their system, dcs?, only lists the O2 sensor good for 100K... I showed them the letter the original owner received but that didn't help.. if it's not in their system they will not do it. They suggest I call MINIUSA which I did... MINIUSA ran my VIN and same thing.. only the O2 sensor covered. No powersteering motor or fan listed...
Now, it maybe have to do with location of where the vehicle was originally sold I dunno. I didn't bother digging deeper into this matter of what else was required to meet this warranty besides mileage and year but mine isn't covered.
So in the mean I ordered a SPAL fan which I will install when it gets here. I also have the power steering delete when crap hits the fan wayyy down the road.. rip all of it out.
#141
#142
09R56
11-16-2022 10:49 AM
marendt428
08-08-2015 04:44 AM
