R50/53 Just got my clutch replaced with Valeo and noises...
Hello NAM Folks,
Wondering if I can get some insight from you...
I just had my clutch replaced with the Valeo kit (everything recommended to be replaced by WMW)...
Now after the mechanic installed it there's is like a grunting/vibrating noise that occurs when in gear 1-6 starting from 0 - 1.5k RPM and it's pretty darn loud...
Just wondering if any of you have experienced this with a clutch replacement or even if not, what you think it can be...
Help! Im taking back to the mechanic who installed (who is a friend of a friend who worked at an auto shop) seems to know what he's doing but I figure this was his first Mini...
Thanks ahead of time,
SEN
SEN
The Valeo kit uses a solid flywheel where the stock clutch uses a dual mass flywheel (DMF).
Mini engineers designed the drivetrain around the DMF, without it you'll get all sorts of noises and vibrations. To make matters worse, not having a DMF can cause very high stresses in the crankshaft.
Should have stuck with the stock kit. Yes, it's expensive. But it works.
I installed a Valeo kit in a 2002 S and there were no wierd noises or vibrations, in fact I was surprised how smooth and effortless it was compared to the stock unit it replaced.
Have your mechanic check out his work, something is amiss......maybe you have a bad motor mount?
0- 1.5k is pretty low RPM. You may just be bogging down the engine. I know I was doing that when I first installed my valeo clutch. It took me a while to get used to the new clutch feel, much lighter than the stock. Try reving to about 2500 rpm at take off, to see if it smoothes things out at all. I have no strange sounds/ vibrations 5000 miles into it.
And no, not having a DMF won't necessarily cause extra stress on the crankshaft, an unbalanced flywheel will, but the way the crankshaft is installed in this car it won't really cause any harm during abrupt shifts.
thanks but this is defintely not a normal sound... And not bogging... The sound happens in every gear... Also when depressing the clutch shifting into gear (no accel) it makes a grinding slight noise when going back to neutral...
The DMF dampens torsional harmonic vibrations in the crankshaft that would otherwise cause momentary stress spikes.
For more info, see what the engineers that designed the DMF in these cars have to say (pages 74-75):
http://www.schaeffler.com/remotemedi...loquium_en.pdf
could be throwout bearing related
I just wonder when they drain the oil out the tranny what they put back in? and the valeo clutch disc will not go in if it put in backward.
Vibrating and grinding as well
Hi,
Just had the single mass clutch done on my 04 MCS, same issue you (Sensez) reported. Makes a grinding sound when pulling from low RPM (all gears) and while in neutral there is a good amount of vibration if the engine speed is held around 1200 to 1500 RPM.
did you find out the problem on this?
Thanks!!
tonywa28
FWIW - I'm not interested in the SMF/DMF discussion, both have merits and weaknesses. The problem I am experiencing (like the original poster) is definitely not an SMF vs. DMF issue. its much more basic like an installation issue or parts compatibility issue. Nobody would be okay with VALEO SMF solution under these conditions and I'm not picky when it comes to NVH.
Feel free to carry on the flywheel debate..... there are millions of both types in service.
Thanks!!
tonywa28
Can a video be made and posted on youtube or shared? I'd like to know about this before I have my Valeo SMF clutch kit installed. Also, in regards to the throwout bearing, was the MINI OEM bearing used or a Valeo one?
I'd asked before because the throwout bearing I got with my kit was different than the OEM throwout bearing. I was told by Valeo and Bavauto that the OEM MINI one was used, I've seen other kits on ebay with the OEM MINI bearing but the one in my kit was completely different.
Be sure to keep the Valeo warranty card BTW....
Fwiw
I don't think a video would give any usable information on this type of issue. It's a "feel" issue, but fairly obvious. I don't expect this will turn out to be some generic problem with the Valeo SMF kit. Too many of them out them already with good results. I expect it is an install issue.
Once I get this back from the mechanic I will post what parts were used. I assume they used the parts included with the kit (including TO bearing).
tonywa28
MCS '04 (2 of them)
69 Lotus Elan S4 S/E
59 Austin Healey Bugeye Sprite
tonywa28
MCS '04 (2 of them)
Agreed
I also think its loose H/W. probably flywheel bolts..... a little wobble could cause the symptoms as I see it (vibration in neutral at low RPM, bit of grinding in each gear when pulling from low RPM). wouldn't take much to show the imbalance or rub a case....
We'll see...
We'll see...
Hello NAM Folks,
SEN
SEN
R50/53 Replacement AC compressor??
PrimePower
Aug 16, 2015 06:29 PM
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
