R50/53 What Temp Range should my 2006 Mini be running at?
Old Nov 27, 2012 | 07:29 AM
prewarkid's Avatar
prewarkid
1st Mini owner (2006 r50)
My temperature guage is running right in the middle between cold and hot. Seems like it's running slightly hot?
What does your temp guage run at? Is halfway too hot? I just had the water pump replaced due to a leak but no improvement.
Old Nov 27, 2012 | 07:48 AM
ViperNL's Avatar
ViperNL
Unless you have the chrono pack, the gauge only shows 3 settings: cold, warm, overheating.
If you want to know the exact temp, get a scangauge or an ultragauge
Old Nov 27, 2012 | 08:10 AM
prewarkid's Avatar
prewarkid
Hmmm I will double check the type of guage. It appears to be a standard temp guage with a needle. Thanks for the tip
Old Nov 27, 2012 | 08:53 AM
submitaweasel's Avatar
submitaweasel
Using my ultra gauge I can tell you...when the gauge first moves above cold the coolant is ~80* F ... it first hits the middle section "normal temp" at ~160F and continues to sit there up until ????
The highest I've seen since I got the ultra gauge is 205ish and it was still sitting in the exact same spot on the temperature gauge. Hell, when I was testing my fans it made it up to 220ish (converted from the onboard "secret menu" readout) and the gauge was still in the middle.
Old Nov 27, 2012 | 09:31 AM
prewarkid's Avatar
prewarkid
Thanks this helps alot. I'm used to seeing the needle on my Honda Civic sit at about 1/3 of the stock temp guage vs. 1/2.
Old Nov 27, 2012 | 10:11 AM
submitaweasel
Well at least we have a temp gauge 2nd gens don't even have one you'd expect more fron an "ultimate driving machine"
Old Nov 27, 2012 | 10:15 AM
prewarkid's Avatar
prewarkid
LOL true that
Cereall
Sep 5, 2019 06:05 PM
rckrzy1
Aug 11, 2015 06:06 PM
sungjk
Aug 5, 2015 08:23 PM
rphox2003
Aug 5, 2015 11:34 AM
