R50/53 Rear Bearing/Hub Replacement
Old Sep 12, 2012 | 07:49 AM
Supergreen03's Avatar
Supergreen03
We have had the typical noise coming from the back of our 2003 S which reading up tells me I had a bad bearing in the rear of the car. I guess after 255,000 miles it can be expected. I purchased two new ones not sure what I was getting myself into having never changed one out before. I bought mine from Rocks Auto made by Timkens. From looking around it was a good price and Timkens is a leader in bearings.So I bought two because if one has gone bad the other probably isn't far off, might as well do both at the same time. This turned out to be one of the easiest things I have done yet to my car. So having discovered that, I wanted to post a little step by step to encourage other people to save them selves some money and do this on their own. There really is no reason just about anyone can do this on there own. Tools needed for this little task are as follows: flat blade screw driver, T20 Torq head, 7mm Allen wrench, 13mm socket and ratchet with 6 inch extension, open end wrench optional I used for leverage with my Allen wrench. And of course a hydraulic jack and a safety jack stand.
1. Jack the car up, put a safety jack stand under it and take the wheel off. 2. Pop spring off of caliper with the screw driver.Rear Bearing/Hub Replacement-2012-09-08-18.27.52.jpg Pop caps off the caliper holding bolts on back side and unscrew with Allen wrench. Rear Bearing/Hub Replacement-2012-09-08-18.30.08.jpg Pull the caliper and brake pads off. Set caliper aside, prop it up on something not to let it hang by the brake hose.
3. Take brake disc off by unscrewing T20 torq head bolt. Now I did this by screwing two of my lug bolts back in and putting my jack handle between them as leverage against the ground to hold the disc from turning.Rear Bearing/Hub Replacement-2012-09-08-18.21.47.jpg 4. Now you are down to the hub which has the bearing in it. The four 13mm bolts are accessible from the back side using the 6 inch extension to remove them, it will take a little elbow grease they're tight. That's it, once the new hub is bolted back in place (I didn't have the torque spec handy so I just made them really tight). Reassemble in the reverse order. Make sure when bolting the new hub back in that you pay attention to the small bump on the inside of the hub. I believe the bump went up on mine. Happy Motoring!
Old Sep 12, 2012 | 07:52 AM
Supergreen03
Wanted to add one more Pic
Here is a pic of the new hub/bearing in place, I could't add it earlier.Rear Bearing/Hub Replacement-2012-09-08-18.42.19.jpg
Old Jan 1, 2013 | 11:49 AM
fastzombie's Avatar
fastzombie
I just discovered this post as I'm having some rear wheel bearing issues. Is the hub assembly difficult to remove once it is unbolted? Thanks for the post as I'm going to attempt to replace them on my own.
Old Jan 1, 2013 | 11:59 AM
Braminator's Avatar
Braminator
Nice write up. Great job. Now go out and have some fun.
Old Jan 1, 2013 | 04:26 PM
Supergreen03
Fastzombie-Once you unbolt the hub it just falls off. Just pay attention to the dircetion the hub bolts in, there is a top to it. Just look for the flat spot and line it back up when you rebolt it in. It took me under two hours to do both in my back yard taking my time its really easy to do.
Old Jan 1, 2013 | 04:43 PM
fastzombie's Avatar
fastzombie
Thank you so much for the detailed description and especially the pics. As they say, a picture is worth a thousand words.
Matt
Old Sep 27, 2013 | 06:22 PM
boobiedaddy's Avatar
boobiedaddy
Thanks for the info it helped out greatly.
Old Sep 27, 2013 | 09:36 PM
Raven Mocker's Avatar
Raven Mocker
Always be sure to buy good quality bearings. You dont want to have to do this again or have something lock up or come apart at higher speeds.
Old Sep 28, 2013 | 05:52 AM
boobiedaddy
I bought duralast. But my problem was the bolts. My dealer had to special order them so I went to the hardware store an bought some grade bolts and reused one old bolt. Two of the new bolts when in with me just turning the extension by hand an the other two (1used) went in snug with me having to use wrench. Once I used the wrench they tighten down on washers. I will replace them with oem bolts when they arrive. I will check them to make sure there still tighten today after some more running around, but I don't feel comfortable with them. Thanks Raven for advise when it come to DIY all advice is needed.
Old Sep 28, 2013 | 06:07 AM
boobiedaddy
One more piece of advice I can give, make sure you get a torque wrench. I snapped two lug bolts.
boostedhaze
Jan 2, 2018 07:26 PM
squawSkiBum
Oct 2, 2015 09:21 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
Minibeagle
Aug 13, 2015 10:00 AM
