R50/53 Installing aftermarket car alarm
Old Jun 4, 2012 | 07:22 PM
ReggieD's Avatar
ReggieD
I am installing an aftermarket car alarm in my daugther's 2004 Mini Cooper_S. I have two questions.
a) What is the color of the door trigger wire for the driver door and passenger door. If possible can I have the wire color and pin number of the two wires at the General Module Control Unit that lead back to the door pins switches. This module is located in the passenger kicker panel
Reason: I need both these wires to trigger the alarm upon opening the driver door or passenger door.
b) How do I remove the interior plastic door jam, theshold. I am not sure what you call this device. I know I am suppose to use a wedge device to pry it off. i am not sure what section or what direction to pry toward. My fear is I will damage it if I pry in the wrong direction. I need to remove this so I can remove the passenger kicker panel.
Old Jun 13, 2012 | 08:33 PM
ReggieD's Avatar
ReggieD
I was told it could not be done due to the car's electronics. Well its done. I hope the infor below can help someone. My hobby is car electronics.
Alarm Installed and fully operation.
Alarm installed: Crime Guard Keyless Remote Alarm 350i5
with Shock sensor, kill switch, car-jack mode, flashing blue LED
Alarm pin out connection that interface to car 2004 Mini Cooper S:
note: GMCU means General Module Control Unit, located in passenger kick panel.
13-pin
Ground - Black - Car frame
Flashing light - White - Car GMCU - Blue plug - pin 27 Black
(use a relay to swap 12+ pulse to ground pulse to trigger lights )
12 volts - Red - Car Battery +12v, Use fuse to connect at battery
Accessory 12v - Yellow - Car cigarette lighter +12v accessory wire, use fuse.
Door trigger - Green - Car GMCU -Black plug - pin 22 , pin 42,
2 same color wires Brn/Gray/yel for both doors trigger
use diodes to isolate both wires from each other
Trunk unlock - Grey - Car GMCU - Black plug - pin 24 - gray/brown
3-pin
Lock (-) - Green - Car GMCU - Blue plug - pin 44 - yellow/red
Unlock (-) - Blue - Car GMCU - Blue plug - pin 42 - yellow/brown
If you need more information just reply to post.
Old Jun 15, 2012 | 12:15 PM
astroBlackMetallic_Mini's Avatar
where did you find the wiring for this?! i have been wanting something just like this for some time, as you can get decent alarms for cars for like $100 these days! i just refuse to have some shop do it, using those awful splice-in connectors... those are only for SOLID wire, NOT stranded! but people use them like crazy...
can you take any pics? i want to see if the wiring is the same for an '06 !
Old Jul 5, 2012 | 11:12 PM
oliverz's Avatar
oliverz
yeah, I would agree that most of them are almost $100 nowadays since transmitters has been included but still there are affordable auto electronics you can see. I'd be interested to see post images for installing your car alarm too...
Alkaidovich
Jan 30, 2021 01:35 AM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
1chaos52
Aug 24, 2015 01:28 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
