R50/53 04 MC passenger airbag removal?
Old May 8, 2012 | 08:11 PM
Rallymini370's Avatar
Rallymini370
Anyone know how to do this as the UK Haynes manual is different to mine.
Old May 9, 2012 | 06:14 AM
Rallymini370
I got up early this morning and figured it out. The top of the dash has to come off to get at the air bag and cover.
Old May 9, 2012 | 09:18 AM
nharrison21's Avatar
nharrison21
I just did this to my 04 MC this weekend..
You will be looking for:
4 screws on the sides of the dash to pull top of dash completly off
2 bolts to remove the retaining bar that holds cover when airbag deploys
6 screws around shroud which hold it all in.
FYI
Disconnect battery before you do any of this as you are working around the airbag
View this post to see the dash completely off
http://www.dcmetrominis.org/forums/s...ead.php?t=2166
Old May 9, 2012 | 12:38 PM
Rallymini370
Cheers! Yes I had the battery off hours before!
Old Mar 12, 2015 | 08:56 AM
Mudhen's Avatar
Mudhen
Does the top of the dash just pull up and off? I undid the 4 torx bolts...felt like I was about to break the cover, though.
Looking at the manual that looks to be it, although they're removing the entire dash - do I need to loosen the 4 big bolts that hold the whole dash up? There's nothing holding the dash cover down in the middle?
Thanks!
Old Mar 12, 2015 | 10:12 AM
Mudhen's Avatar
Mudhen
Thanks!
Nevermind on this one...found that my '05+ isn't as easy as this. ARGH. All I want to do is disable the stupid thing so my navigator doesn't get a rally computer implanted into his skull in case something bad happens on a little TSD rally.
madmaxxed
Aug 24, 2015 11:56 PM
greekzilla
Aug 23, 2015 03:44 PM
DWooderson
Aug 10, 2015 09:12 AM
quality_sound
Aug 7, 2015 09:36 AM
