R50/53 Dyno day disappointment
Old 02-01-2012, 08:12 PM
Cheerio44's Avatar
Cheerio44
Cheerio44 is offline
I saw a post by someone a while back who needed a new bpv, his numbers where significantly low, and as soon as he changed it the dyno showed HUGE gains. Definitely seems like it's that. Changing the BPV isn't too hard, I did it in like an hour with basic tools. DT ones are $125. I have my old one at home (I changed it for the DT one, still works fine though) if you want I can ship it out to you, just pay me for the shipping.
  #27
Old 02-02-2012, 07:24 AM
stranger55's Avatar
stranger55
stranger55 is offline
Originally Posted by wiayeman
How does it feel on the road? Does it do 0-60 in less than 7 seconds? According to those numbers, it should take about 17 seconds.
Kinda hard to find a decent place to try 0-60 in my area. Best I could do was cost thro a right turn at about 10mph, then dropped into 2nd pushed to 5500rpm(about were dyno shows no increase), 3rd to again about 5500rpm and passed 60mph in about 8 seconds. Was about a 30% grade hill I was climbing an on ramp.
Is there any way I can check the ecu to see if it has the mini jcw tune from factory? Id hate to bring it in and pay just for them to tell me I do have it
Cheerio, PM inbound. Thanks
  #28
Old 02-02-2012, 09:21 AM
BlwnAway's Avatar
BlwnAway
BlwnAway is offline
If it's a factory JCW the dealer has probably done the proper updates.
Zip Tie your BPV closed and then drive it to see if it makes a difference or not, if so, replace it, if not start looking somewhere else. (it will not hurt the car to drive with the BPV closed, just don't leave it that way.)
  #29
Old 02-02-2012, 11:36 AM
rickyr53's Avatar
rickyr53
rickyr53 is offline
Damn dude. I think im having the same problem with my car. It dyno'd at 117whp with an intercooler sprayer
  #30
Old 02-03-2012, 07:14 AM
stranger55's Avatar
stranger55
Im not sure how to Ziptie it. But got another bpv inbound, hope I see a differance.
Ive also ordered some stock IC boots(from research best solution compaired to aftermarket) just to put my mind at ease. Also gona reverse the flapectomy on the jcw box just to see if there is any differance.
  #31
Old 02-03-2012, 01:01 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
You zip tie the bpv so the air from the sc cannot escape...
The purpose od the bpv is to open at idle/low rpm situations when power is not needed....ehen itopens, the air from the sc is vented, removing backpreasure on the sc, reducing the load on it, and this the motor....it is done to improve fuel economy ....and when it is venting fully, you mini has less hp than just a cooper since an s has lower compression pistons.
The spring on it can break or the seal goes bad....or the vac lines to it get cut....end result, little or no boost.
  #32
Old 02-03-2012, 06:13 PM
Hound_va's Avatar
Hound_va
Hound_va is offline
I wouldn't like seeing my AFR down around 11 at approximately 4200 RPMs.
  #33
Old 02-03-2012, 11:03 PM
BlwnAway's Avatar
BlwnAway
BlwnAway is offline
Thats actually normal for a factory tune on a MCS, the factory tunes rich @ WOT, for engine safety (one of the reasons being unknown gas quality) this is one of the major factors in tuners being able to get extra hp out of even stock motors.
I still think it's a BPV issue due to the hp-vs-tq spread.
  #34
Old 02-04-2012, 10:16 AM
Cotnballs2000's Avatar
Cotnballs2000
Cotnballs2000 is offline
Under full boost this is what you want to prevent detonation. Going down to around 10.5:1 will get you max HP under full boost.
  #35
Old 02-04-2012, 10:47 AM
mc40monster's Avatar
mc40monster
mc40monster is offline
Just wondering, When you were at the Dyno day were you the only Front wheel drive car? My experiance with low numbers on a Dyno with a front wheel drive car is that the dyno wasn't corrected to rotate in the opposite direction. Of course if this was a four wheel dyno or the hub style then never mind.
  #36
Old 02-04-2012, 11:07 AM
BlwnAway's Avatar
BlwnAway
BlwnAway is offline
Actually 10.5 is too rich, 11.5 is about right.
10.5 is good for a bottle though.
  #37
Old 02-04-2012, 03:23 PM
stranger55's Avatar
stranger55
There was some VW fwd, at about 318whp. I followed it. idk if they adjusted it though
  #38
Old 02-04-2012, 04:56 PM
Cotnballs2000
Not on the the tunes I have seen on the dyno, none have been on a Mini so I can not speak to that. The happy range is 10.5-11.5 under full boost and WOT I will agree with you there but dialing in the advance and AFR you still gain at 10.5:1
USA-RET
11-09-2015 07:27 PM
M7Speed
R60 :: Countryman Talk (2010-2015)
09-04-2015 10:47 AM
M7Speed
09-03-2015 07:48 AM
M7Speed
R58 :: Coupé Talk (2012+)
09-03-2015 07:29 AM
M7Speed
09-03-2015 07:27 AM
Quick Reply: R50/53 Dyno day disappointment
