R50/53 Time for new injectors?
Old Nov 22, 2011 | 11:16 AM
niquemarshall's Avatar
niquemarshall
Ive noticed that my 2004 MCS is starting to consume much more gas than normal. Its gotten to the point where its going thru a half tank in about three days off of just regular driving, less than ten miles a day.... Is it time for new injectors? Or fuel filter?
Old Nov 22, 2011 | 12:13 PM
TimMc's Avatar
TimMc
The injectors could be leaking, but that seems like an awlful lot to not have noticed a drivability issue to go with it. I would look for other leaks in the system. Does it smoke (black) alot?
Old Nov 22, 2011 | 01:50 PM
proximo's Avatar
proximo
Usually filters or injectors won't show in a reduction of fuel economy, but I can see a loss in leaks. Do you notice any odors or water spots where you park? The computer could be choking the car more not reading something right and pushing more fuel into the combustion chamber? Dirty air filters? Do you have an ODB log reader to tap into the computer and see how the numbers are flowing?
Old Nov 22, 2011 | 02:32 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Is there gas in the oil?
Does the car start ok?
Old Nov 22, 2011 | 04:19 PM
niquemarshall
I highly doubt there is gas in the oil since the car runs fine...
Old Nov 22, 2011 | 04:20 PM
niquemarshall
No black smoke.. Ran seafoam in the summer too
Old Nov 22, 2011 | 04:22 PM
niquemarshall
Well I restarted the mpg consumption and the numbers seem to be jumping around... No gas smell around the car either
Old Nov 22, 2011 | 04:42 PM
ScottRiqui's Avatar
ScottRiqui
Has this been going on for several tanks? Could it be that you're just having an fuel-quantity indication problem, rather than actually only getting 5 MPG?
Old Nov 22, 2011 | 04:59 PM
niquemarshall
Well it's been like this for a couple tanks, idk what it could be because at times the distance to empty actually coincides with odometer, but not always. Also normally when it gets down to below 70 miles to empty, it will only have one tick. However it is still showing two ticks
Old Nov 22, 2011 | 07:16 PM
niquemarshall
I have the one ball exhaust mod and it's great on power and I have been getting on it lately, but it's been doing it before I did the mod
Old Nov 22, 2011 | 11:06 PM
niquemarshall
Well i will check the air filter as i havent changed it all year (since i bought it used in feb) hopefully thats the thing. Will also check injectors
Old Nov 23, 2011 | 02:50 AM
HRM's Avatar
HRM
Maybe some D-bag is stealing your gas.
Old Nov 23, 2011 | 04:12 AM
ZippyNH's Avatar
ZippyNH
The obc is pretty inaccurate...and running the fuel tank to almost empty is VERY BAD FOR THE PUMP...IT IS COOLED BY THE REMAINING FUEL IN THE TANK....hot pump= failure in less time.
Injectors can get drippy...usually results in a hard start...or stuck open..motpr stoppage...if they were spraying too little fuel, you would get lean codes, and better mpg...worse mpg may mean you are getting close to needed a pair of o2 sensors....
A bottle of injector cleaner will not hurt....
In some parts of the country the change over to winter fuels, and folks idling a bit to warm up kills mpg....
Old Nov 23, 2011 | 05:20 AM
ScottRiqui's Avatar
ScottRiqui
I hate to admit defeat when it comes to troubleshooting, but I'm at a loss. If you're really down to 5 MPG, but the car feels like it's running fine,then it's not anything as simple as a dirty air filter or the new one-ball exhaust mod.
Frankly, HRM's idea that someone is siphoning gas makes more sense than anything else I can think of.
Old Nov 23, 2011 | 07:15 AM
gknorr's Avatar
gknorr
If you haven't replaced the 02 sensors yet, that could be part of the problem - especially the one before the catalytic converter. Often, a failing 02 sensor will give you a SES light though.
Old Nov 23, 2011 | 07:32 AM
mini44's Avatar
mini44
Does your kid steal it after you've gone to bed? I used to do that. lol
Old Nov 23, 2011 | 11:11 AM
niquemarshall
Well I usually fill up when the counter gets to 40 miles to empty... As for hard starts, it's always turned a few times more than what I'm used to.. The idle used to get a little lumpy in the summer, but hasn't happened for a few months now. At the shop they're saying maybe switch to a better grade of gas
Old Nov 23, 2011 | 11:15 AM
niquemarshall
Update: checked spark plugs. They're fine
Air filter is slightly dirty but nothing serious, haven't been able to find a place that sources these filters... Tire pressures look good.. Car ran extremely well this morning.. No evidence of a leak.. And I lock my doors do the gas isn't stolen, also accOrding to the obc this fuel is being consumed... IDK WHAT'S GOING ON
Old Nov 23, 2011 | 11:24 AM
jimz68's Avatar
jimz68
Has the fuel filter ever been changed?
Jim
Old Nov 23, 2011 | 11:52 AM
niquemarshall
Jim
Not to my knowledge.. But im hearing that wont cause a drop in fuel economy
niquemarshall
Lol hahahaha im only 20 myself
Old Nov 23, 2011 | 04:24 PM
MINI33342's Avatar
MINI33342
Don't trust the OBC for calculating fuel use....it is notoriously inaccurate. Get a calculator and do the math yourself when you fill it up.
Old Nov 23, 2011 | 07:04 PM
Eric_Rowland's Avatar
Eric_Rowland
True. I'm OCD about mileage - the OBC on mine has ranged between 1% and 19% too high, with an average of 11% too high.
6 gallons over 30 miles makes no sense at all. You should be seeing or smelling that type of usage.
Old Nov 24, 2011 | 07:40 AM
niquemarshall
Hmmm so i made a thanksgiving drive and got about 400 to the whole tank.. Ran injector cleaner but I'm still seeing the range jump around at the slightest change of speed
Old Nov 24, 2011 | 07:50 AM
vIPkOhH's Avatar
vIPkOhH
^+1 for this...The Pre Cat sensor could be the problem,have you tried to get the car scanned for codes?My pre-cat sensor failed and showed codes even tho the SES/CEL light didnt come up at all...
