R50/53 done anything dumb lately?
Old Mar 24, 2010 | 01:56 PM
  #26
Kathy1946's Avatar
Kathy1946
..." He points to wording right next to the *** that says ....."Push to Start"
Old Aug 29, 2010 | 01:30 PM
  #27
mallor6's Avatar
mallor6
my first post
I know this is an old thread but i have to share this...
I was just finishing up a SC pulley install and was using one of those T-bars that takes a bit in the front. Well i was just about done when the bit fell out the end and dropped straight down the dipstick tube.
I had to drain the oil, pull the oilpan, get a new gasket and actually had to take the next day off work and borrow a car for the night!!
Old Aug 29, 2010 | 01:43 PM
  #28
NightFlyR's Avatar
NightFlyR
That sucks, bet you could not do that if you tried,
Old Aug 30, 2010 | 03:57 AM
  #29
Fatherdeth's Avatar
Fatherdeth
That's not dumb, that's just bad luck!!! Did your oil pan gasket leak before having to pull the pan? If it did, then it wasn't a total waste.
Old Aug 30, 2010 | 04:30 AM
  #30
howsoonisnow1985's Avatar
howsoonisnow1985
Yes
Just watched The Last Exorcism
JK
I broke the aluminum hinge that holds GP panel down, trying to open hinge more.
Old Aug 30, 2010 | 04:46 AM
  #31
mallor6's Avatar
mallor6
Yeah, my oil pan was kinda leaking so i guess it worked in my favour.
Old Aug 30, 2010 | 10:15 AM
  #32
Some Guy's Avatar
Some Guy
Some may have seen the thread: I broke the clip that hold the coolant sensor on doing a diff swap. I also forgot to reconnect the sensor for the backup light, which is buried deep in the engine bay.
Old Aug 30, 2010 | 01:05 PM
  #33
Ortholad's Avatar
Ortholad
I forgot that the paper gasket on the Redline oil bottle was loose and when topping up I forgot to look to make sure the gasket was still in the cap. Since I didn't see it stuck to the top of the bottle, I poured it into the valve cover (sigh). I thought long and hard about it and decided it would be chewed up and filtered out without damage...I've been watching the oil presure gauge for 4000 miles and knock on wood, so far no problem.
Old Sep 21, 2010 | 11:27 AM
  #34
XXLil MickXX's Avatar
XXLil MickXX
I have the auto and I am always changing the radio station when I am meaning to up/downshift
Old Sep 21, 2010 | 11:35 AM
  #35
erickvonzipper's Avatar
erickvonzipper
Ive done this a couple of times, the first time in my Saturn years ago:
I thought I was a big shot when I got into the car and smoothly backed it out of the gate. Of course, in my coolness-of-being, I neglected to close my door and sprung it. Car doors dont like opening 130 degrees.
Almost did this in the MINI but caught it just before the basketball pole in the driveway did irreparable damage.
Old Sep 21, 2010 | 11:41 AM
  #36
MiniR53's Avatar
MiniR53
I was plasti-dipping my car recently, and when i went to remove my chrome gas cap to clean and paint it, it slipped out of my hands and fell on the concrete floor. I chipped it pretty bad , but at least I painted it so it doesn't show.
Old Sep 21, 2010 | 11:54 AM
  #37
Keyser_Soze's Avatar
Keyser_Soze
This is a rhetorical question, right???
ericbryant24
55
Sep 30, 2024 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Panik
Sep 9, 2015 08:36 AM
bcman
Aug 28, 2015 04:47 PM
lebrunseven
Nov 6, 2004 08:19 AM
