R50/53 Problems putting cas in my car!
Problems putting gas in my car!
When I try to fill my '06 Cabrio the pump keeps shutting off if I use the thing on the pump handle (wide open fill, so I can wash my windows while gas is pumping) or if I squeeze it to high flow. It happens at different stations. I have been filling up cars with gas for many years and have never run into this problem before! What gives?
Try putting the nozzle all the way into the neck, then pulling it out 1 turn on the coil that wraps around the nozzle.
It maybe goes without saying, but you're not gassing up with the engine running, are you?
The reason I ask, once upon a time, I sold Mitsubishis, and the gas pump wouldn't stay operating if the engine was running. It had something to do with emission controls, or so I was told.
Basically if having the nozzle not as far in doesnt work...use a different pump...which usually means go to a different station. Ive got a mental list of places I cant get gas anymore lol
So it happens to you, too? I have tried a few different stations and it still happens.
yeah once you find the sweet spot itll completely fill while you clean the windows... just takes practice... i assume you havent had the car for a while?
I've had the same issue consistently. There must be a hard turn in the filler tube right about where the end of the nozzle is when you push it all the way in, that tricks it into thinking it's filled you up. Pulling it out just a hair solves it.
I've found that pumps that have excellent (FAST!) gas flow makes the pump shut off. I will usually have to squeeze it a little less, and at stations with crappy slow pumps, I never have any problems.
-Chase
-Chase
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
bc219
Aug 10, 2015 11:22 AM
