R50/53 Will these rims fit my 04 JCW?
Old Nov 19, 2008 | 07:56 AM
pimpedout97x's Avatar
pimpedout97x
15x7 stock rims from an Integra (1992-1995)
i THINK they're a 44 offset.
and im pretty sure i just have the normal S breaks, not the JCW. not 100% sure though. how can i check if these will fit before i buy them (they're about 1.5 hours away)
i like the style of the rim and id prally paint them flat black, or maybe gold to see what they look like
http://i85.photobucket.com/albums/k5...7/PC070078.jpg
Old Nov 19, 2008 | 08:51 AM
Dan00Hawk's Avatar
Dan00Hawk
According to this : http://www.team-integra.net/forum/di...g+Common+Topic
and this:
http://www.rims-and-wheels.com/acura...y71660u10.html
They are only 15x6. The bolt pattern is the same as the Mini, but I don't know what offset it is. If the person selling them is telling you they are a 7" wide rim, don't bother dealing with him...
Old Nov 21, 2008 | 06:18 AM
blkkouki's Avatar
blkkouki
i would have him take a picture of the back honda/acura has all the measurements stamped on the back there will be a 15x?jj and possibly the offset. and if i remember correctly the normal offset is a +42mm
Old Nov 21, 2008 | 06:29 AM
pimpedout97x
i believe it is a 42 offset.
for 300 bux for those rims in the pic, with tires, which look to be good tires and not bald or anything, thats not bad. just to have some other rims just to switch it up every now and then
Old Nov 21, 2008 | 06:28 PM
glnr13's Avatar
glnr13
you don't have the JCW brakes.
42 offset for 6" wide or 7" wide will fit.
will it clear the front caliper? i don't know about that. you'll have to do a test fit. you might need a 3 or 5mm spacer to clear teh caliper if the spokes don't leave enough room behind them. you should test fit them on the rear too, i remember a 15" wheel by enkei not clearing the bolt at the bottom of the suspension.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
Aug 12, 2015 01:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
