Exhaust leak!? 2006 JCW SIGNIFICANTLY louder/"ricey'er"
Could use some help here:
I have a 2006 MCS (JCW) with ~23k miles on it. A couple weeks ago I had new tires put on at a reputable SoCal shop along w/ an alignment. Coincidentally when I picked the car up it was significantly louder than it has always been w/ the stock JCW exhaust. I called the shop to ask if anything was perhaps loosened and then not tightened, they mentioned it wasn't (what I figured just getting an alignment done). The only description I can make is that the car w/ the stock JCW exhaust was throaty under throttle and had the standard pop around 3k rpm when letting off, however it didn't at all call attention to itself in a parking garage or parking lot driving normally looking for a space to park. I now have a car that is SIGNIFICANTLY (2x+) louder. Likely had nothing to do w/ the tires except timing, but do you guys think I have an exhaust leak and would it be worth tightening bolts on the exhaust system before taking it in to the dealer? (still under warranty, but a pain). Anyone else ever experienced this? it's like I stuck a crappy sounding muffler on my great car I love! Help! Thanks |
why don't you back it up onto ramps and check the torque on the
pipe? :confused: :) |
Lucky!
I recently had a customer that had a JCW exhaust crack and leak at the center mounts. Maybe this is what has happened to your car. I've seen about 50 05-06 cars with stock exhaust leaking at the welds on ther rear mufflers.
Well that sucks. None of it is covered by warranty?
i also have a 2006 JCW, had the same problem, leak at the center mounts, covered by warranty...dont worry
Crackerjack/Miniguru- thanks, hope this is it!
Originally Posted by MINIGURU@WAY MOTOR WORKS
(Post 1931770)
Originally Posted by crackerjack
(Post 1931838)
(Post 1931770)
| All times are GMT -7. The time now is 12:18 PM. |
