R50/53 Shipping car w/OEM alarm
Old Nov 19, 2007 | 12:35 PM
qweewq12's Avatar
qweewq12
Tomorrow I will be shipping my car from HI to MD.... the shipper requests me to deactivate the car alarm...
Instead of having to take it in to the dealer twice to have it turned off and turned on.. I want to just unplug the siren... I know I can do this as I installed the OEM alarm when I got the car...
Anyone see any issues with this and thinks I should just take it in to have the dealer do it?
Thanks!
Old Nov 19, 2007 | 12:40 PM
Newdl's Avatar
Newdl
there is a way for you to (when you lock it) deactivate the alarm. I bleive you should look in the book that came with your mini about the alarm system..it should inform you.
Old Nov 19, 2007 | 12:46 PM
qweewq12's Avatar
qweewq12
I do understand that...
But the Joe Blows on the ship and on the trucks from HI to MD isn't going to know, care or want to be dealing with that..
Old Nov 19, 2007 | 12:52 PM
Eric_Rowland's Avatar
Eric_Rowland
You should be fine just disconnecting the siren. Because it's all integrated, it's not like add on systems that require a seperate fob and can be activated/set off without using the key.
Old Nov 19, 2007 | 12:57 PM
qweewq12's Avatar
qweewq12
Thanks Eric... didn't know if disconnecting the alarm would trip some code in the ECU causing a check engine light or something...
I don't care about the lights flashing.. but the siren going off might cause someone to throw a sledge though the window...lol
Old Nov 19, 2007 | 12:59 PM
MDK's Avatar
MDK
Will you run into trouble with the lights flashing or the immobilizer if you just disconnect the siren?
Old Nov 19, 2007 | 01:17 PM
qweewq12's Avatar
qweewq12
with who? the shipper?
Takes about 3 weeks to get there... I think it might go off a few times during the ship ride over... but not so much while on the truck or sitting in wait for transit... battery should be fine... if the lights are blinking, but the siren is off, then I don't think the shipper would care...
With all the cars that get shipped, should be fine.. just don't want it to stick out in the crowd...
the immobilizer might be an issue... maybe I will just try it tonight...
Old Nov 19, 2007 | 01:32 PM
Eric_Rowland
I'd go ahead and do a dry run, but I can't see that there would be an issue, other than perhaps the alarm light might not flash/flash fast to let you know that there is an issue.
In the '06 the tilt sensor is integrated with the siren, so nothing should set it off. You could disconnect the I/R interior sensor as well, for good measure. With no inputs I can't see how the alarm would trigger.
The immobilizer is based in the ECU/chip-in-key interface, so it doesn't have anything to do with the alarm.
Let us know if you see any side effects of disconnecting the siren.
Old Nov 19, 2007 | 06:46 PM
chpsk8's Avatar
chpsk8
Any chance the tilt sensor would go off due to the ship rocking?
Is there a fuse you can pull? I don't think I'd want to risk my alarm going off for 3 weeks. I bet that would kill a battery.
Do they jump it if it's dead, or just push it over the edge... "Mini? sorry, we no see no Mini onboard this trip..."
Old Nov 19, 2007 | 09:33 PM
qweewq12's Avatar
qweewq12
alright... it is done... I un-did the 1 bolt & 1 nut and pulled the siren out tonight...
Everything works fine... even the alarm & panic, but just no alarm siren, only flashing lights...
Also, the beep & beep-beep for lock & unlock are gone too... go figure...
sweet.... better than paying the dealer... will just throw it back in when I get to the other side...
Old Nov 20, 2007 | 05:21 AM
MDK's Avatar
MDK
I was thinking about problems with a dead battery but it sounds like that will be OK, good luck with the move!
Old Feb 11, 2008 | 03:40 AM
qweewq12's Avatar
qweewq12
To close my experience on this, the car arrived eventually w/o harm. Everything was in working order it appeared. Re-installed the siren and everything was back to normal. No issues.
Old Feb 11, 2008 | 07:17 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
What company did you use? Do they go international? In a few years I might need an international shipper.
Old Feb 11, 2008 | 08:36 AM
Chris P's Avatar
Chris P
Isn't there a seperate fuse for the alarm system that can be removed?
AWOL
Mar 28, 2016 10:51 AM
O4mcs
Aug 10, 2015 10:22 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
