R50/53 Jacking up the car onto jack stands
Old Oct 2, 2008 | 04:12 PM
  #51
miniconcarne's Avatar
miniconcarne
Originally Posted by BlimeyCabrio
BlimeyCabrio,
I posted this link on MINI5280 forum. Club member was wondering "how-to"
and your's is a great one. Thanks.
Old Oct 13, 2008 | 08:03 PM
  #52
Sin MINI's Avatar
Sin MINI
Originally Posted by kenchan
i have a R53 and lift the car behind the front factory jack point where you see a verticle rail that goes down the side of the car. it's partically covered with side molding plastic. ive been using that location number of times. best to have a hydraulic with a larger flat platform to spread the weight.
Any chance you can post a picture? Or measure how far back that point is from the jack. Not clear to me...thanks!
Old Oct 25, 2008 | 03:28 PM
  #53
Sin MINI's Avatar
Sin MINI
I rotated half my tires today (too many distractions to finish, plus I was cleaning my no-longer-white wheels) but noticed something odd. I jacked up the car under the front jack point high enough to put in the rear jack, then used the subframe as a jack point to get the stand under the front jack point. That's when I noticed that the car was not even resting on the rear jack stand...it was hovering approx half-inch above with the weight entirely on the front jack stand. To lower the car I just pull out the rear stand, jacked the car higher from the back jack point until the front was high enough to pull out the stand, then lowered the car.
Anybody else notice this?
Old Oct 25, 2008 | 03:43 PM
  #54
AKIndiMini's Avatar
AKIndiMini
Yup, I noticed this shortly after I bought my MCS. I think it's just that the vehicle's structure is so stiff. I'm sure it's short wheelbase has something to do with it as well.
It makes for quick winter tire changeovers though! I basically just lift from the forward jack point w/ my floor jack until both wheels on one side are just barely off the ground. Swap wheels, lower vehicle - repeat on the other side.
Old Oct 26, 2008 | 03:06 PM
  #55
BlimeyCabrio's Avatar
BlimeyCabrio
Yep... also, it's so stiff that if you put it on four stands and set one stand 1 click lower than the others (so about 1/2") the car will hover above the lowest stand by at least 1/4"... that ain't much chassis flex, folks...
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
