R50/53 JCW Intake Install questions
Old Sep 10, 2007 | 12:32 PM
QXXOTIC's Avatar
QXXOTIC
I just attempted to install my JCW CAI and I'm also lost on the location of the vacuum hose connection.
I remember seeing an install procedure SOMEWHERE that had actual images rather than the diagrams on the "official" install..
Any hints or a pic on where this is SUPPOSED to connect? I think I have the rest figured out OK.
Thanks for your help!
Jim
Old Sep 10, 2007 | 01:55 PM
Crashton's Avatar
Crashton
Jim, I've sent you a PM about this.
Welcome to NAM
Old Sep 10, 2007 | 02:03 PM
BlimeyCabrio's Avatar
BlimeyCabrio
When I did mine (which I THINK I did the right way - and all works OK) - I pulled the hose off the bypass valve (I think that's what it is... the black plastic thing on the side of the throttle with a black vaccuum hose attached to the top) then connected up the T-hose from the JCW kit there.
It's much easier to access this if you remove the plastic cover from the intercooler...
Old Sep 10, 2007 | 02:07 PM
Crashton's Avatar
Crashton
Jim, check your e-mail. I sent you the pictures.
Old Sep 10, 2007 | 02:17 PM
Crashton's Avatar
Crashton
Good tip Blimey. There isn't much room & every little bit extra helps. I cut my hands to ribbons doing mine.
Old Sep 10, 2007 | 03:18 PM
dstrass's Avatar
dstrass
Can you send me the pics as well.Getting ready to do mine.
Thanks.
Old Sep 10, 2007 | 03:30 PM
Crashton's Avatar
Crashton
I'll post them here. These are not mine I just happened to save them to my hard drive.
Old Sep 11, 2007 | 07:50 AM
jibeho's Avatar
jibeho
Do yourself a favor and go and buy a longer hose then what is provided.
Old Sep 11, 2007 | 08:01 AM
BlimeyCabrio
I really didn't have a problem with the hose LENGTH... just the location...
Of course, I had the intake hose removed from the throttle body also - which helps a lot. But then you need a clamp to reattach it (I'm using an Alta hose...)
Old Sep 11, 2007 | 02:04 PM
Crashton's Avatar
Crashton
The guy who cuts that vacuum line for the kit is a cheap son of a gun. Not a millimeter extra. It's just long enough. Barely!
Old Sep 11, 2007 | 02:49 PM
dstrass's Avatar
dstrass
Thanks!
Alkaidovich
Jan 30, 2021 01:35 AM
silence2-38554
Nov 12, 2015 09:39 AM
papawhiskey
Aug 10, 2015 09:31 PM
