R50/53 How do I remove the antenna pod on the roof of an 06?
Old May 19, 2007 | 02:13 PM
early_apex
My kid just broke the antenna off of our 06 with a frisbee. How do I get that pod off to replace it? I thought on the earlier cars you just turn it 90 degrees and it comes off but this one looks different.
Does anyone happen to have one of those for sale?
Old May 19, 2007 | 02:16 PM
mini_dreams's Avatar
mini_dreams
on my 2006, the pod stays on the car and the antenna just unscrews from the pod.
did he break the pod itself? or just the antenna?
Old May 19, 2007 | 02:29 PM
early_apex
The pod broke. The antenna tore out the top of the pod.
Old May 19, 2007 | 02:33 PM
early_apex
Not cool
Old May 19, 2007 | 02:40 PM
Grassroots Garage's Avatar
Grassroots Garage
You'll have to pull the C-pillar trim back from the top (this is tricky and breaks easily) and the boot seal. Pull the headliner down some, and you'll see the nut on the bottom of the antenna unit.
Good luck
--Dan
Old May 19, 2007 | 02:42 PM
early_apex
Originally Posted by Grassroots Garage
the C-pillar trim (this is tricky and breaks easily)
Thanks for the help.
does the C-Pillar trim just pop off?
Old May 19, 2007 | 02:47 PM
Grassroots Garage
it has a screw behind the side panel, so no. You may be able to just remove the top bit of bott seal, and see if the headliner pulls down enough to get to it. otherwise, you may have to disassemble some of you interior. These cars seem to be built from the top down! Take a look, but don't remove it until you have a part to replace with
Old May 19, 2007 | 03:08 PM
early_apex
The part is $35 from Patrick MINI if anyone is curious. Their parts guy John was really cool to work with.
Old May 19, 2007 | 03:27 PM
ARTSJCW's Avatar
ARTSJCW
OOOOOUCH. They must be making stronger Frisbee's than they did when I was a kid....come to think about it, that has been a looooong time!!!!
Old May 19, 2007 | 03:38 PM
early_apex
I thought I had all of them put away, but he got his hands on one of these:
They will take your head off if you aren't careful
Old May 19, 2007 | 04:25 PM
ARTSJCW's Avatar
ARTSJCW
That is amazing
bjcarter2
Aug 31, 2015 04:03 PM
bugeye1031
Aug 15, 2015 08:14 AM
ludedude
Aug 10, 2015 07:16 PM
