Dyno Testing at NCA'08
Make your reservations here to have your MINI/Mini measured for wheel horsepower at the Nevada City Adventure, May 17th, 2008. Each participant will receive a full color print-out of cars performance. Introducing a radically different approach to chassis dynamometer testing....
http://new.minimania.com/web/Item/DY.../InvDetail.cfm http://www.minimania.com/banners/dyno-check.jpgThe Dynapack! - the only unique and technically sophisticated dyno available today in a market that is crowded with cookie-cutter designs. We have SOLVED the problem of tire slippage and the inconsistencies of the tire to roller interface - while our competitors try to pretend that these problems don’t exist. If you’ve operated a roller dyno, you know better. We’ve started with a clean sheet to design a dyno that truly performs and exceeds customer expectations. Why settle for a “standard” dyno when you can have so much more. The Dynapack is a true load-brake dyno - just like the best engine dynos. We directly measure the work being performed, while others just estimate it. Since we have real hydraulic load brakes, we allow you to perform tests that simple inertia-dynos are incapable of. You can now have unprecedented control over the vehicle with a degree of resolution and precision that has to be seen to be believed. The Adventure Starts here! |
| All times are GMT -7. The time now is 03:00 AM. |
