Navigation & Audio New Hack/Mod - Qi Wireless Charging in Armrest
I just got my 2013 Countryman a few weeks ago, and I'm one of those folks that's chosen a Nokia Lumia 920 over iPhone. Bluetooth integration is great, and other than having no way to invoke voice commands to send a text, everything in the car works perfectly (audio streaming, etc), other than having to plug it in to charge.
The Nokia has a wireless charger built in though, so I decided to hack together a mount in the armrest of the car. It's not pretty yet, I wanted to see if the functionality worked first.
Install (parts list below):
I can take pictures if anyone would like.
Parts:
1) Griffin short lighter to USB plug
2) Qi Wireless charging pad (usb powered)
http://www.ebay.com/itm/QI-Standard-...item257aed8f86
3) Case for Samsung Galaxy Player 5.0
http://www.bestbuy.com/site/Rocketfi...988&st=samsung player accessories&cp=1&lp=14
4) Some double-back sticky tape to connect the player case to the charging pad
- Remove the iPhone tray from the armrest between the driver and passenger seats
- The wireless charger should just about fit. I had to shave the head end a bit as the armrest tapers towards the front
- Plug the USB cable into the wireless charger, and run it out of the back of the armrest
- Plug the Lighter adapter into the power outlet behind the armrest, and the USB cable into that
- Use the double-stick tape to affix the galaxy player case to the wireless charger plate; I had to put it near the top for the charging coil to line up with the phone
- Drop the phone in and go
Parts:
Hey jameslew
I found your post while searching for USB powered Wireless Charger on the net as I was thinking about fitting out my car with a Wireless Charger for for my Lumia 920 also.
I actually joined this site just to reply to your post.
I would like to see some photos from your mod if you dont mind, as it will give me a few ideas of my own hopefully.
Cheers.
Cheers.
gar56
11-15-2016 06:41 AM
