Navigation & Audio Installed iPod Video using Nav Display
Old Dec 28, 2006 | 10:42 PM
Dr Obnxs's Avatar
Dr Obnxs
with the video switch from TVANDNAV2GO. I bought it used in the Martketplace..... Went pretty smooth except for one thing.... I'm hooking up an iPod video to the nav screen/aux port, and I can't find the four connector mini-jack plug and socket! I wanted to modify the aux port connector so that it was a clean install, instead I'll add RCA plugs for Right and Left audio and Video. Then it's just a single cable to hook up.
Works pretty good too! I put the module in the nav case, but had to lengthen a bunch of the wiring for the run under the carpet to the front and back consols.
One thing I did learn was that the dishwaser does a great job of cleaning the consols! I took them all apart, and did the painted parts by hand. Put the big pieces in the dishwasher with the rest of the dishes and they came out great! I've had my car over 4 years and they were pretty spuzzy....
One other thing is that the switch only does video. I'm thinking of making an auxiliary switch for the audio, so that I can acutally use both video inputs, and add a DVD player into the glove, and not have to screw with cables as the audio would switch with the video source.... Just a bit more work....
Matt
Old Dec 28, 2006 | 11:33 PM
billie_morini's Avatar
billie_morini
From a neophyte: Are you saying you can play ipod video on your navigator screen?
Old Dec 28, 2006 | 11:58 PM
Dr Obnxs's Avatar
Dr Obnxs
Yep...
and the stereo comes out the factory stereo via the aux input. The plan is to play photo slideshows that will keep the girl from fussing (she's two...). There are a lot of ways to get this done......
Matt
Old Dec 29, 2006 | 03:53 AM
mdsbrain's Avatar
mdsbrain
Glad to see you got it hooked up Matt.
Old Dec 29, 2006 | 10:32 AM
tom @ eas's Avatar
tom @ eas
Matt
Correct - you will need to use a separate AUX input for your audio.
Have you seen our Video Integration kit from Dietz? this will allow an Audio/Video source to display and is completely Plug and Play:
Dietz Video Multimedia Interface - 1265
http://www.europeanautosource.com/pr...roducts_id=338
adrchn
Aug 13, 2019 02:11 AM
emulajavi
Dec 24, 2018 09:15 AM
squawSkiBum
Oct 2, 2015 09:21 AM
