Navigation & Audio TomTom One
Old Dec 26, 2006 | 08:33 PM
Jtrem's Avatar
Jtrem
TomTom One
Does anyone have this unit? I got it for christmas and I am looking for a goodway to mount it. Thanks!
Old Dec 27, 2006 | 05:59 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Me too.. I havent yet but im leaning to attaching it to my Driver side sun shade. Other spots bottom of the steering wheel since i have the two spoke design. the Driver side defroster where some have put there Gtech. Currently using it as intended on the windshield so its just below the rear view mirror
Old Dec 27, 2006 | 08:36 AM
Jtrem's Avatar
Jtrem
See I can't put it on my window. Its illegal here in CA. Im thinking about drilling a hole in the dash and mounting it through there.
Old Dec 27, 2006 | 11:34 AM
TouringComet's Avatar
TouringComet
I'm planning on mounting my Sirius plug and play unit through the dash. I've pulled the center color trim piece off, and moulded into the back side are two cylinders, in just the right spot to put the device to the side, just below the vent, and high enough that it won't block the radio. Drill through the cylinders, and run the bolts through.
A good mount for GPS units is the Kuda mount. Puts your GPS device up where you can readily see it. KUDA
Old Dec 28, 2006 | 11:56 AM
Mugami's Avatar
Mugami
Ok made a quick mounting for the TOMTOM .. which also allows it to be moved from car to car easily
What i did is get a piece of Stiff plastic a type that the suction cup will hold on to and double side taped it to the Defrost ring as shown
Yeah i know its a very rough cut. I wanted to make sure it worked before i trim it further
Been riding around for a bit and seems to hold even on the potholes and rough bumps around here
Old Dec 29, 2006 | 11:31 AM
Jtrem's Avatar
Jtrem
Has anyone figuered out how to cancel a route on the TomTom One?
Old Dec 29, 2006 | 11:36 AM
krolyat's Avatar
krolyat
yes, but my unit is currently in a undisclosed location so i can't physically look at it. I will have a clear answer (if the one below doesn't work) when I pull it out.
But you have to enable all options to be available (or i had to on mine). Then go to settings/options and it's on the 3rd screen in on the top right hand corner.
Old Dec 29, 2006 | 11:47 AM
Jtrem's Avatar
Jtrem
Thanks! Ill check it out. It was kind hard to get used to. This was a replacement of my Nuvi 350 that was stolen. The navi in my G35 is very straight forward. This one just mixes me all up. haha
