Navigation & Audio Another speaker replacement question
Old Aug 9, 2006 | 10:33 AM
soilsample's Avatar
soilsample
Hello all,
I'm considering installing some full range 6X9s in the rear of my H/K equipped MCS.
I usually listen in the "electronic" mode.... because some of the other listen modes produce too much echo/delay sound.
If I understand correctly, in the electronic mode, the rear speakers are only Subs.
So my question (finally) is....
If I install some 2 or 3 way 6X9s in my car, will I have to listen in another mode in order to utilize the mid/highs in the 6x9?
Donald
Old Aug 9, 2006 | 10:38 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by soilsample
Hello all,
Donald
The rear 6x9 speakers for the H/K audio system are not normal 6x9 speakers so you cannot replace them with normal 2 way or 3 way speakers and expect them to function.
Search for more info on the H/K audio system- see review and how to set the controls for H/K.
See
http://www.mini2.com/index.php?page=...item&newsid=10
Point Source modes with “Driver” feature available:
Three settings:H/K MINI (Gentle Hollywood Curve), Electronic (Generous Hollywood Curve), and Instrumental (Flat response): all use Rear speakers as subs
Diffuse modes:NameSoundNotesSpacial (Gentle Hollywood Curve) has EQ and slight delay (?) to rear
Festival (Gentle Hollywood Curve) has Delays in front and reverb to the rear.
Old Aug 9, 2006 | 10:47 AM
Holemeister's Avatar
Holemeister
Factory 6x9s
The H/K 6x9s are actually dual voice coil subs. As far as the crossover points for the subs, thats internal to the H/K amp.
Old Aug 9, 2006 | 12:22 PM
GBMINI's Avatar
GBMINI
The rears are also 2 ohms.
If you put a "normal" full range 4 ohm single coil speaker in there, you would reduce output power by a factor of 4! And you wouldn't get more highs, since the H/K amp isn't sending them to the rear speakers.
Old Aug 9, 2006 | 02:30 PM
soilsample's Avatar
soilsample
2 ohm speakers in the rear? wow, I'm glad you told me that.
Does anybody sell 2 ohm 6x9s?
So I guess the best bang for the buck would be a nice set of components for the front......
The rears produce enough lows for my listening, but the front is lacking a bit in the mid and upper range sound (IMO).
I'd like to get a little louder too, I can hardly hear the radio when the windows are down on the highway.
I understand that an amp will be about the only way to get "louder"..... but I figured an upgraded speaker with some dynamat might get me closer to what I'm looking for.
Thanks for the input
Donald
Old Aug 9, 2006 | 05:14 PM
cristo's Avatar
cristo
Alliance Member
Infinity Kappa 692.7i or 693.7i are both 2 ohm 6x9 full range speakers
with very high sensitivity (95 db/W).
Old Aug 9, 2006 | 05:20 PM
GBMINI's Avatar
GBMINI
Tacotim - a one time NAM member (still around?) - measured the H/K and found the speakers VERY efficient. He said most aftermarket speakers will reduce the maximum volume since they are less efficient.
silence2-38554
Nov 12, 2015 09:39 AM
theblackfalcon
Oct 11, 2015 09:49 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
thebordella
Aug 31, 2015 01:37 PM
OutMotoring
Aug 6, 2015 09:32 AM
