Navigation & Audio xm Roadie2
Old Jun 5, 2005 | 08:35 AM
dexter2317's Avatar
dexter2317
xm Roadie2
Does anyone use the XM Roadie2? Is this a simple solution to the scrolling issue with satellite radio? Would someone please show a picture of this system mounted in your mini?
Old Jun 6, 2005 | 05:31 AM
cra_fizzer's Avatar
cra_fizzer
A Roady2 doesn't scroll. Sorry . You think that this day and age that they could. I mounted ours on the "big" cupholder.
Old Jun 6, 2005 | 12:29 PM
HowardPM's Avatar
HowardPM
I use
the roady 2 in my mini. I keep it lying on the cigarette lighter cup holder thing. Its connected to my AUX input. The only thing I don't like about it is you can't see, the station name/number, the artist and song at the same time. You only get 2 out of the 3 depending on the display setting. Another issue I also have is the signal str. isn't as good as it could be, I keep the antenna on my right passenger side dash, but ocassionally it cuts in and out. I don't want to put it outside since my cars the convertible and would rather not put any wires through the seals.
Howard
Old Jun 6, 2005 | 06:04 PM
dexter2317's Avatar
dexter2317
Wow, I'm kinda thinking that I should just get the Sirius subscription even though I currently subscribe to XM!
Old Jun 7, 2005 | 04:46 AM
cra_fizzer's Avatar
cra_fizzer
If you haven't purchased the Roady2 yet, I would highly recommend buying the MYFI instead. Awesome unit.
Old Jun 8, 2005 | 07:32 PM
stever's Avatar
stever
Blitzsafe only option for me
buy the xmdirect package through blitzsafe. I have it and wouldn't trade for anything. connects through the cd changer ports. all sterring wheel controls work. I had a sirius tuner with a blitzasfe adapter for a cd changer. It did not display any information on the head unit only station numbers.
Old Jun 16, 2005 | 08:00 PM
Smokey's Avatar
Smokey
I've got both the xm direct and the roady and are you ready for this........ I prefer the roady, so much I moved the direct to the wife's car!
Yes the xm direct is nicely hidden and a very clean install and interfaces with the MFSW (with the exception of the mode button on the 05's, what's up with that? ) But I like to see what is playing before I go to a channel and the direct entry method of channel selection is way better then scrolling manually.
The first time I mounted mine, I did it on a homemade bracket that came up between the wiper switch and the dash.
This time I used a gimble mount and the 35mm film container trick. I like!
They're right the roady doesn't scroll, but it will show you more info then the xm direct or factory unit will.
Good luck with your decision.
Old Jun 16, 2005 | 08:12 PM
rrdusek's Avatar
rrdusek
xm roadie 2
i have the roady 2 and transfer it from my mini (big cup holder) to my work truck and back. please tell me "what is the 35 mm film canister trick".
Old Jun 16, 2005 | 08:32 PM
Smokey's Avatar
Smokey
You take your normal 35mm film canister, the plastic type and use that as a base for whatever you want to mount. The canister fits over the trim on the hazard or dimmer **** for the interior lights. I drilled a hole in the bottom of the canister and into the gimble mount and poured quick setting epoxy to bond the 2 pieces together. Works great, and hasn't wiggled a bit on these roads around here.
Have a pic, sorry for quality, but I just took them a few minutes ago.
Edit: from the drivers seat the unit doesn't block the speedo as much as photo 3 makes you think.
Old Jun 17, 2005 | 06:21 AM
rrdusek's Avatar
rrdusek
xm roadie 2
thanks smokie, guess i'll be mixing epoxy this weekend.
Old Jun 17, 2005 | 06:32 AM
HowardPM's Avatar
HowardPM
hmmm
So you need to pull that off to turn on your hazards. I kinda like the 2 push buttons around the speedo (or the nav system in my case) looks very retro and different.
Old Jun 17, 2005 | 10:12 AM
Smokey's Avatar
Smokey
Or pull it off to dim the interior lights; 6 of one, half dozen of another
As I said I like the features of the roady over the xm direct and with the second antenna I bought, I can easily move the unit to my other rides, be they cars or aircraft
