Aux Cord part number
My daughter wants an Aux plug for her stock R52. I watched a video on YouTube stating that the dealer has a plug in to the back of the radio (with a square plug). Does anyone have a part number or a place to get an aftermarket Aux Cord?
Look here for part numbers, usually. realoem.com
Here’s a link to the MINI cable: https://www.ecstuning.com/b-genuine-...t/82110153367/ A member just just recently installed this aftermarket cable which is less than 1/3 the price: Depending on the configuration of your car, it might be necessary to transfer the pins from the aux cable plug to the existing plug on the radio with either cable, no cutting/splicing of wires should be needed as incorrectly mentioned the video I saw. |
Originally Posted by Minnie.the.Moocher
(Post 4433429)
Been there-done that-no help. |
Originally Posted by RB-MINI
(Post 4433433)
Here’s a link to the MINI cable: https://www.ecstuning.com/b-genuine-...t/82110153367/ A member just just recently installed this aftermarket cable which is less than 1/3 the price: https://www.amazon.com/dp/B015F5ZWMA..._Zm13BbC1TAA0K Depending on the configuration of your car, it might be necessary to transfer the pins from the aux cable plug to the existing plug on the radio with either cable, no cutting/splicing of wires should be needed as incorrectly mentioned the video I saw. |
Originally Posted by jjcsnlynn
(Post 4433435)
Thanks. This is the one.
Edit: figured out the NAV is the yellow wires. I need to remove them and put them into the new aux plug. Thanks. |
I would put the aux wires into the NAV plug in case the pins get damaged removing them. It would be better to have something go wrong with the cheap aux cable than the harness for the NAV. The MINI installation instructions include the additional steps for the pin relocation when necessary. If the MINI cable doesn't come with instructions they can be found online.
