Navigation & Audio mini F56 navigation retrofit
Old 09-15-2018, 11:06 AM
vikislap's Avatar
vikislap
vikislap is offline
hi,
I just started to install navigation unit screen and touch controller to my f56 originally with regular radio...all works fine but no navi and bluetooth need some help to get coding for it..
I do have esys cable and I can talk to my mini but I do not have this code list like I did for my countryman before.
I can see my list of all modules installed from mini but I do not know what to add and what to delete .... radio and put the code for navi
in esys is it under salapan list you can edit it... can somebody help ? maybe to reed it from yours car and send it to me... and also if there is possible to change the vin by esys...
any advice will be great
Thanks Vik
Old 09-19-2018, 12:25 AM
6FT6's Avatar
6FT6
6FT6 is offline
What exactly did you install? Not much info to go on.
Old 09-19-2018, 01:21 AM
vikislap's Avatar
vikislap
vikislap is offline
Had this regular radio and now navigation unit touch control...
I am done now just need coding to unlock all futures on it...
Attached Thumbnails mini F56 navigation retrofit-photo47.jpg   mini F56 navigation retrofit-photo219.jpg
Old 09-19-2018, 05:40 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Did you look in the other recent retrofit thread? https://www.northamericanmotoring.co...y-project.html
MiniCooperJP did the same project, and can probably point you to a source for FSC Codes.
Old 09-19-2018, 06:24 AM
vikislap's Avatar
vikislap
vikislap is offline
Wow thank you so much for this input I did not see it before...
Old 04-29-2020, 01:01 PM
edvavi's Avatar
edvavi
edvavi is offline
Pls help!
hi,
Thanks Vik
I have the regular radio and a friend of mine has the one with touch controller and he just loose his car in an accident so he is selling me his radio but I don't know how hard is gonna be the change. If I buy it from him its plug and play or I need some special cables or something, I just read on your post that you are having hard time setting up the navi but what else work and what doesn't? Pls.
Old 04-30-2020, 09:59 AM
ASKtheteach's Avatar
ASKtheteach
ASKtheteach is offline
What did you need to do to get everything installed to this point? Was it plug and play or was there wiring splicing and cutting of the internal dash required? Also, for the iDrive controller in the console, was the wiring already there under the storage cup or did you need to add that too?
Old 05-07-2020, 04:04 PM
VINTAGA A I's Avatar
VINTAGA A I
VINTAGA A I is offline
Nací mini f56
[Quote = vikislap; 4420397] Hola,
acabo de empezar a instalar la unidad de pantalla táctil de navegación y el controlador de mi F56 originalmente con radio normal ... todo funciona bien, pero sin navi y Bluetooth necesitar algo de ayuda para conseguir que codifica para ella ..
que hago tengo cable esys y puedo hablar con mi mini, pero no tengo esta lista de códigos como lo hice para mi compatriota antes.
Puedo ver mi lista de todos los módulos instalados desde mini, pero no sé qué agregar y qué eliminar .... radio y poner el código para navi
en esys está en la lista de salapan puedes editarlo ... alguien puede ayuda ? tal vez para que la caña de la suya coche y enviarlo a mí ... y también si hay posible cambiar el vin por esys ...
cualquier consejo será grande
Gracias Vik [/ quote]
Old 05-07-2020, 04:05 PM
VINTAGA A I
Mabi mini f56
Hola buenas
como hiciste, y q hizo falta ,?
funciona todo correcto ?
dsludis
Brad Bedell
How to
10-20-2021 10:54 AM
kfinkl
09-10-2017 08:03 AM
Bank999
Navigation/Audio
08-30-2015 08:51 PM
ryanschram
06-26-2010 03:09 PM
AutobahnRat
08-04-2009 05:13 PM
Quick Reply: Navigation & Audio mini F56 navigation retrofit
