limp button on tiptronic shifter
Old 07-02-2018, 03:12 PM
audihere's Avatar
audihere
audihere is offline
My tiptronic automatic transmission has a shift lever with release button that feels too loose. Is there a spring or anything in there that might be broken or worn out? In some shift positions the button doesn't spring back out like I think it should.
I found info on how to pull it off online. Not sure if I can fix this one or need to buy a new one, or if it's something down below the center console?
Old 07-06-2018, 04:45 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Going to move you to the Stock Problems/Issues section.
Old 07-06-2018, 09:24 AM
audihere's Avatar
audihere
audihere is offline
I have a feeling the shifter button rod that goes down inside the car isn't being pulled back down. When I depress the button on the shifter, there isn't anything pulling the button back out, unless I use my finger to pull it back out.
Old 07-06-2018, 09:38 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Might find some info here https://www.newtis.info
Old 07-15-2018, 06:39 PM
audihere's Avatar
audihere
audihere is offline
I pulled the shifter off of the shaft. Should the button have a spring or something inside it that forces it back out when pressing on it? Right now, there's no resistance.
Alexdrod
07-20-2010 08:09 AM
ChesapeakeTechie
07-07-2007 09:38 PM
22350
30
03-31-2003 09:53 PM
Quick Reply: limp button on tiptronic shifter
