Navigation & Audio GPS hardwire for 2017 F54
Old 02-17-2018, 03:43 PM
Lucas63's Avatar
Lucas63
Lucas63 is offline
Has anyone had any luck finding the right wire to use? I spent a lot of time today trying to find a wire I could tap into to power my Garmin. All I accomplished was having an emission error light appear because I tried using a wrong open spot on the fuse box. The only wiring info I could find was instructions for a Click and Drive but it was too old and the wires in my car are different. The other source was another set of instructions from MINI for a GPS mount and wiring for the Garmin they sell with the MINI logo, but again that info was wrong and it didn't match my wires. Even though the wires in both instructions didn't match my wires I did use a meter to check the wires in the same pin locations but the wires were live with the ignition off, so that was a no go. Without a wiring diagram I would just be guessing. Someone must have solved this problem. Maybe there is a set of new Click and Drive instructions out there that actually apply to this model?
I thought about tapping onto the power wire for the 12v outlet in the dash but I don't know how to take that part of the dash apart to access.
Old 02-17-2018, 04:06 PM
TVPostSound's Avatar
TVPostSound
TVPostSound is offline
https://docs.google.com/document/d/1...jg-Q2NQY28/pub
This is how I did mine.
"lighter" power stays on for about 4 or 5 minutes after ignition off.
Old 02-17-2018, 04:15 PM
Lucas63's Avatar
Lucas63
Lucas63 is offline
I had seen that on the Cravenspeed site, where I bought the mount but the access panel to the lighter socket shown in the picture is for an F56. The Clubman area for that socket is much smaller. Does anyone know how to access this socket in an F54?
Old 02-17-2018, 08:51 PM
pw1114's Avatar
pw1114
pw1114 is offline
You can find what you need right here:
https://www.newtis.info/tisv2/a/en/f...rays-consoles/
Basically, it all pulls right out.
You're right that there is not a lot of room in there. When I added a second hidden socket, I used the 12V socket from the back below the rear vents. Theres a lot of room in that area.
Lucas63 (02-18-2018)
Old 02-17-2018, 11:33 PM
rkw's Avatar
rkw
rkw is offline
That's very strange. Tapping into power shouldn't trigger an error. You should be able to use a fuse tap (like Littelfuse Add-A-Circuit) in any fuse position open or occupied, and you only need to choose between a switched or always on fuse. You can tap the cigarette lighter fuse and it would be electrically equivalent to connecting to the back of the lighter itself (at least the hot side, not the ground).
Old 02-18-2018, 05:42 AM
Lucas63's Avatar
Lucas63
Lucas63 is offline
Thank you! That site is great. Will be very useful in the future.
Old 02-18-2018, 05:51 AM
Lucas63's Avatar
Lucas63
Lucas63 is offline
I was disappointed when the emissions light came on. I used a meter to check what open circuits in the fuse box would be controlled by the ignition switch. The only open ones were with a few 5amp fuses that the paper diagram labeled emissions. I can post a picture later of the fuse box to show the exact location. My guess is the car monitors amp draw in that circuit and when it exceeds a set level that triggers an emissions fault reading. Hope it clears itself. Does anyone know?
Old 02-18-2018, 01:33 PM
Lucas63's Avatar
Lucas63
Lucas63 is offline
Garmin is up and running, thanks to the info pw1114 provided. The emissions error light went away too.
eseel
08-26-2016 05:17 PM
qrysdonnell
Electrical
11-06-2012 02:03 PM
grips03
Electrical
03-11-2012 03:23 PM
onefish2
Electrical
01-16-2009 07:50 AM
gnhovis
02-18-2004 03:59 PM
Quick Reply: Navigation & Audio GPS hardwire for 2017 F54
