Navigation & Audio Failed amp, new HU, but not sure best solution
Old Jun 20, 2019 | 11:37 AM
  #26
mstorck33's Avatar
mstorck33
So I wound up picking up four Kenwood coaxial 6.5 speakers, and I'm going to attempt to connect them to the JVC head unit and forget using any kind of amplifier at all. I don't have the money for one anyway. I've spent hours trying to decipher the wires that plug into the stock H/K head unit, and I feel like I've learned nothing. I have no problem cutting and crimping connectors onto the wires, I just can't figure out which wires do what. If anyone knows any links to a breakdown of the wires that plug into the back of the H/K head unit, please share the links. I'm going to keep searching and trying to figure it out in the meantime...
Old Jun 20, 2019 | 01:39 PM
  #27
gumbedamit's Avatar
gumbedamit
WOW 1.5 years later and you're still trying to get it to work....
Old Jul 6, 2019 | 12:38 PM
  #28
mstorck33's Avatar
mstorck33
Correction: I GOT it to work!!! It took a while and a lot of tracing wires with the multimeter, but I'm going to post a breakdown of what I did and how shortly. It was definitely a pain in the ***, but now I have a working stereo with aftermarket speakers, and didn't have to run new wires through the doors.
Old Jul 6, 2019 | 04:04 PM
  #29
A383Wing's Avatar
A383Wing
Good job.....looking forward to your write-up
Bryan
Old Aug 5, 2019 | 06:45 PM
  #30
mstorck33's Avatar
mstorck33
I took a bunch of photos, going to try and find them tonight and put together a write up. WHo knows, maybe it'll help someone in the future.
Old Aug 11, 2019 | 09:27 AM
  #31
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Old Dec 25, 2019 | 05:22 AM
  #32
varma1986's Avatar
varma1986
I have this head unit pulled from a ?Mini Cooper but am not sure.Can anyone help me locate the exact part number, functions and model applicability of this head unit.Thanks.
Old Dec 25, 2019 | 02:20 PM
  #33
Eric_Rowland's Avatar
Eric_Rowland
That's not a head unit. Looks like the optional Sirius plug in.
Old Dec 25, 2019 | 02:24 PM
  #34
varma1986's Avatar
varma1986
Thank you for the information.I got this item as an add on when i purchased the 8.8" touchscreen display for my MINI.I do not know what to do with it.If i were to sell it back on eBay, what should i advertise it as?.Can this item be an add on on my existing Mini cooper system without Sirius?.What additional features does this bring?.How & where can this bulky item fit when it connects to the main head unit as a slave/supplement?.
Old Jan 15, 2020 | 05:44 AM
  #35
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
Thanks for this thread. My situation wouldnt have happened if my owner could have bought the Sirius unit that varma has :(. I recently purchased a 2008 JCW Sidewalk convertible. The PO wanted Sirius and had an aftermarket radio (with corresponding adaptors) installed. I am removing it to go back to stock. I have the original amp and head unit. Have the current system removed except for an added
wiring harness that is running towards the passenger seat. Since it is nice here today I am planning to remove the passenger seat and search for the origninal harness and remove the added on harness.
The diagrams in the provided links are a godsend
Old Dec 28, 2020 | 01:59 AM
  #36
RecoilFreak's Avatar
RecoilFreak
I am just starting to dig into this HK debacle with my 2005 R52, and I am running into some issues. I bought my car incredibly cheap from my nephew, who had a friend that thought it would be funny to poke his finger in one of the rear speakers. I found a good deal on a pair of Focal 165 CA1 SG's (6.5" coaxial speakers with an internal crossover and post mounted tweeters). I just got done installing them, and the door woofers have stopped working. Also, the Focals are playing very muddled and weak bass. There were two connectors on each rear speaker (DVC's?). I only hooked up one pair on each side to the Focal speakers. I assume that is what caused the door woofers to stop working. Does anyone have any info on my issue? I thought I read above (or maybe it was on another post) that the original HK speakers are 2 ohm - the focals are 4 ohm. How would one go about wiring up both pairs of wires in the rear speakers to the aftermarket replacement speakers? Just join both positives and both negatives to each other and then to the speaker? I don't want to blow up this apparently expensive HK amp. Thanks for any help you can offer.
Old Jul 14, 2021 | 10:06 AM
  #37
toadmini's Avatar
toadmini
I bypassed the original HK amp
I bypassed the original hk amp (using a pinout map) using breadboard jumper wires in my R52…attached an Alexa Auto to the aux input and all is well until I find a replacement amp…easy and cheap fix…$7 spent on jumper wires
philtruitt
Mar 10, 2016 11:57 AM
april4jsd
Electrical
Feb 12, 2007 05:06 PM
SpiderX
Dec 10, 2005 08:54 AM
