Navigation & Audio H/K speaker swap - Use both DVC feeds with SVC speaker?
Old 05-25-2017, 07:31 PM
MassMini's Avatar
MassMini
MassMini is offline
2005 Cabrio with Harman Kardon. I removed my rear interior to track down a short in the top and am considering replacing the rear speakers while everything is out. I know the H/K's rear speakers are 2 ohm dual voice coil and I would be replacing with 2 ohm single voice coil. Can I splice together the feed wires (pos to pos, neg to neg) and feed both to the replacement speaker? I've read posts that talk about using only one of the feeds and thus getting only half the power.
Old 05-26-2017, 08:39 AM
rkw's Avatar
rkw
rkw is offline
Combining different channels of an amp together for more powerful output is known as "bridging" an amp. Running an amp in bridged mode is possible if it is compatible with the internal circuit of the amp, otherwise it could burn out the amp. When an aftermarket amp is bridgeable, it would usually provide a switch for the customer to select between normal and bridged mode. Obviously the HK amp wasn't intended to be run in bridged mode, but that doesn't mean it can't. You decide on taking the risk.
The HK amp is designed for the HK speakers. The amp applies frequency response correction and crossover filters to compensate for the performance of each speaker. It can do this because it expects to be connected to specific HK speakers with known characteristics. If you use an aftermarket speaker, the quality will be unpredictable depending on its similarity to the speaker it is replacing.
rdvnacmini (06-21-2017)
Old 05-28-2017, 12:29 PM
MassMini's Avatar
MassMini
MassMini is offline
Originally Posted by rkw
...Obviously the HK amp wasn't intended to be run in bridged mode, but that doesn't mean it can't. You decide on taking the risk.
Decided to abort the mission. I put some poly fill behind the stock speakers and called it a day.
Old 06-21-2017, 12:45 PM
rdvnacmini's Avatar
rdvnacmini
rdvnacmini is offline
Thanks RKW, super clear and concise explanation of how the HK amp and speakers communicate and why/how system is optimized for the OE HK speakers. Very helpful for anyone considering speaker changes.
