How to play iPhone 7 through 2012 mini w/ bluetooth
So our R60 countryman has the usb/audio ports and the y-wire with apple 30 pin connector. I have an iPhone 7 (no headphone port). Is there a lightning cable that will work to feed audio to the mini's ports so I can listen to spotify or pandora?
Is this what I need? https://www.ecstuning.com/b-genuine-...a/61122408012/
That's it's for the lightning cable phone. I use the pandora app .
(Post 4295986)
Thanks, I'll order it up. I'm really trying to avoid spending a lot on mods for this car. You guys cost me a lot with our past mini R56, Jetta TDI, and Touareg TDI :razz: |
if you have the cable with the 30-pin adapter, you can save some money and buy the Apple 30-pin to lightning adapter. Plug that into the Mini y-cable, then plug the other end into the iPhone lightning port - done. That's how I use mine, and works great.
Seconded.
If you have a Y-cable that was working with an older iDevice, you just need the APPLE 30-pin to Lightning adapter (~$30-40). No need to purchase another $90 cable, but do avoid the 3rd party adapters - they do not work 99% of the time. |
I lost the old adapter, so ordered the cable from ecs.
Originally Posted by Zimm
(Post 4296186)
You should be set then! :thumbsup: |
find someone with NCSexpert and have them change your USB Audio to digital. You will then have audio over USB.
FWIW, I opted for a different route.
I snaked a 3rd party charging cable up to my Cravenspeed phone mount and the purchased a Bluetooth adapter for the audio. The adapter I got was this one. The downside to this adapter is that I have to press a button to activate it when I start up the car. It's powered by USB but has a small battery in it. After turning off the car, the battery will drain, so you have to press the button to power it on after power has been restored. Other than this minor annoyance, it's worked perfectly for me. As an alternative, my business partner bought this model from Banggood which doesn't have a battery. It powers on as soon as you start the car since it doesn't have an internal battery. Hope that helps! |
Is this cable really as short as the pictures make it out to be?
https://www.ecstuning.com/b-genuine-...a/61122408012/ I'm not sure it'll reach my phone sitting in the center console area... Sort of related question: my 2013 clubman I just got has bluetooth capability but I only see "Phone" in the Menu, and there's no BT Audio under Mode. Does this mean I only have phone BT capabilities and no BT audio? :| I did successfully pair it for phone usage... |
Its about 10" long total. Not really short. Its will reach in the cup holder, past that it will not. Works and holds if you have it in the little net in the footwell, if you have a Countryman, Paceman the plugs infront of the shifter and it reaches to the middle of the center console a bit.
(Post 4317816)
Bought a proclip and holder to go with my extension cable lol, feels like 2006 all over again. Some day I’ll just do a custom audio install and have BT audio. |
(Post 4317816)
If there is a holder, works much better. Yea I had mine lodged and flipped right side, but a 6+ phone will not fit in the cupholder so it does not matter.
Dude totally. A plus phone definitely won’t fit.
Thanks btw for the link to the heat shield in that othet thread. I’m on mobile atm so will follow up |
I got this one for my iphone 7 plus. Its pricey and sometimes crashes. You have to reboot your phone when that happens. But i still have steering wheel controls with it so that is a plus.
Originally Posted by Isyvibes
(Post 4317848)
I got this one for my iphone 7 plus. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Its pricey and sometimes crashes. You have to reboot your phone when that happens. But i still have steering wheel controls with it so that is a plus. |
Originally Posted by the_dude_abides
(Post 4317831)
