Navigation & Audio HK Sound...Where is it?
Hello to all...I just picked up my '04 MCS, Liquid yellow, Sport, stripes, roof panels, and HK upgrade. I love the car...2600 miles in 10 Days!!!...but I am not in love with the HK system. Is it just me or do the rear speakers sound like an old Victrola with a wet towel thrown over it? What gives? If I turn the fader to only the back speakers...I've heard better sound from two tin cans tied together with a string. It seems that 98% of the sound comes from the fronts. Are the rears acting as a sub? Other than that, the car is awesome...Borla exhaust, 15% pulley, Alta intake and diverter are right around the corner. Thanks
Check the settings in the unit. Typically it is set to "Driver", which is not bad. Ups the volume when you drive and lowers it when you stop. Plus it "aims" the sound at the driver's seat.
Something else to look at is the setting called.... forget. Anyways, the settings are like "Electronic" and "Ampitheatre" and such. Big difference in sound there.
Most people I have talked to say the bass in the HK system is terrible. Not bassy enough or something. I find the bass overpowers my treble. I have turned the bass down about halfway and it still overpowers the treble.
Oh well. For the most part I am happy with my HK system.
There are several problems with the HK system from a non-audiophile's point of view:
1) the bass is way too strong
2) there is no mid-range adjustment; with the bass so strong it's really hard to balance the system to sound good without it going either all bass or all treble
3) the automatic speed/volume control has never worked very well if at all (it's supposed to increase volume when you speed up to account for road noise, and vice versa, but if it does it's so subtle as to be ineffective). A MFSW is key to counteract this nonexistant function!
I have the HK system in my car as well. I always keep the setting to "Electronic". Thats the setting that pretty much gives me that crisp digital sound. I am pretty much satisfied with it. But you have to keep some things in mind, you drive at high speeds with the windows down and you put the volume to max, the front speakers tend to sound shakey resulting in whatever music you have on not sounding good and as a result you have to put the volume down for it to go back normal again. I think that is the only setback of the HK system.
3) the automatic speed/volume control has never worked very well if at all ... if it does it's so subtle as to be ineffective).
Mine works awesome. Increases the volumn and decreases with speed all to my satisfaction.
:smile:
The rear speakers are almost-subs - there is no mid range or tweeter unit in the rear. In some modes (eg: spatial) some low-mid-range comes from the rear speakers, but their primary job is low frequency.
The HK system is designed to be forward biased (my biggest complaint with it, though I have got used to it).
Check the current H/K audio setting in your stereo. "MINI H/K", "Electronic" and "Instrumental" are all front speaker biased (Front stage) sound processing modes. You will not hear the rear speakers, or if you do, you will get muffled sound from the rear coaxials.
Now modes "Spatial" and "Festival" use all 4 speakers in the car. In "Spatial" mode, your rear passengers will be able to hear the rear speakers or if you prefer to fade the sound stage towards the back of the car, you will be able to do so in this mode.
People don't seem to understand what the different H/K sound processing modes are supposed to do and blame this on very poor user documentation provided by MINI.
:smile: After fiddling around with all the different choices, I've basically settled on the MINI H/K setting as the all-around best. Radio sounds best on that setting and most of the CDs do, too. I have no problems with my auto/speed volume function...works just fine. Wanda is my second MINI, the first one had the stock sound system and the H/K has been well-worth the additional expense.
Clo/Wanda
Clo/Wanda
My 9/2003 build '04 MCS HK stereo equipped car did not come with the speed volume stetting enabled.
Could it be that early build (2003) MINIs with the HK option still offered the speed volume feature and later removed?
If yours doesn't automatically (in the Amp/DSP) adjust the speed volumn, then clearly there's something wrong.
Take it in for service.
A PLAGUE ON MINI of PITTSBURGH!!!
Dominic, I remember seeing a lot of threads from early '03 that all complained about the speed sensitive function not working on the HK. You are the first person I've seen who says it works. Kudos to you. How did you make it work?
Peanut's build date is Jan '03; I have one of the early HK systems that has the speed setting available to fiddle with...
Originally Posted by OmToast
Mine is a Dec '03 build and I have NO SPEED VOLUME FEATURE.
Here's an older thread on some of the basics of the HK system. There's a long post in the middle that's a must read for all HK owners. There's a few followup posts that are good too.
https://www.northamericanmotoring.co...ead.php?t=9236
Enjoy!
Enjoy!
Originally Posted by dominicminicoopers
Are you saying you do not notice any automatic volumn adjustment based on speed? Or are you saying the "SPEED VOL" adjustement screen was removed from the head unit?
There is absolutely, positively, without a single shred of doubt in my mind or in the mind of the many I have enlisted to double check my hearing, NO DIFFERENCE in the volume dependant upon speed.
I do have the speed volume control on the head unit, but was told by my service advisor that that control was only a residual from the Boost system and that it did not function with the H/K system.
My system also has speed compensation such that I rarely need to adjust volume at highway speeds - except if the windows are open.
Since I have an aftermarket HU feeding into the HK amp, I have no "SPEEDVOL" adjustment but it still works because the function is inside the HK amp itself.
For a month or so I had an aftermarket amp and it was obvious to me that there was no speed compensation - I would have to adjust volume at different speeds. As soon as the HK amp went back in, that problem was once again solved.
So GBMINI, are we lucky that we have speed compensation in our HK's or are the other ones out there broken?
Like I said my stereo sounds and works great so not having access to the auto volume prompt does not automatically mean that something is "wrong" with it.
I think we could corroborate with other '04 and '05 HK stereo owners.
Here's another helpful explanation of the various listening modes of the H/K, no discussion of the variable volume tho'
http://www.angelfire.com/in2/guitar/minihkreview.html
Thanks for all of the answers. I guess it is just a matter of getting used to the way the HK system is set up. The sound is good, although it could use a bit more volume...but the HK issue only makes up about 1/2 of 1% of a complaint. The other 99.5% is just awesome!!!
OM,
If you do *not* have the HK upgrade, you should find the SPEEDVOL adjustment and it should adjust the "simple" speed compensation built into the stock head unit.
If you *do* have the HK upgrade, your head unit may or may not be "smart" enough to hide the SPEEDVOL adjustment - but either way, it has no effect.
On the HK, all speed compensation is internal to the HK amp and follows a fixed and non-adjustable algorithm. Maybe not the best but that is how it is.
I was driving in to work today and noticed initially that the volume did not need adjusting as I increased in speed on the highway. But then I got to a bit of highway with noisier surface, and I did need to bump up the volume one notch. So HK compensation adjustment would be nice but presumably just too difficult for the programmers to achieve - instead they chose a "typical" subtle compensation.
