Navigation & Audio Very Poor FM & AM Reception
Old Jun 30, 2014 | 06:21 AM
mikeyb74's Avatar
mikeyb74
On my 2009 Cooper S with the standard sound system with Bluetooth and Aux Input. Bluetooth, aux input, and the CD player function properly. It has started to have very poor or static reception for both FM & AM. I have had a Cravenspeed shortie antenna installed for over 2 years. I swapped out with a OEM shortie and even tried a stock whip antenna but still having the same problem. The only time a radio station comes in is if I'm near the broadcasting tower. This all started when I was using my ELM 327 Wifi OBDII scanner with my iPhone5.
Any ideas? It's very annoying. I don't usually listen to the radio but when using the Wifi OBDII scanner I am unable to stream Pandora.
Old Jun 30, 2014 | 12:02 PM
Kevin@Integral Audio's Avatar
Check to make sure you are getting power to the antenna diversity module.
Old Jun 30, 2014 | 01:13 PM
mikeyb74's Avatar
mikeyb74
I'm about to remove the boot lid interior panel to check the cables. Did not think of testing the power while I'm there.
Old Jul 3, 2014 | 08:16 PM
dthtrp's Avatar
dthtrp
Also, When you remove the antenna diversity, verify no water ingress into the module itself. I have seen situations where no water or corrosion was found at the connections, but inside the antenna module itself was corroded.
dthtrp
wildwestrider
11
Jan 29, 2016 05:06 PM
zdw2082
Oct 5, 2015 09:59 AM
rustof
11
Sep 25, 2015 10:35 AM
Septimusminious
Sep 14, 2015 08:47 PM
