Navigation & Audio Pulling my hair out wiring this aftermarket stereo (Pioneer DEH-X6600BT)
This should work out for you. Give it a try and report back to me!
Interestingly I only get the reading when I am touching to the ground pin. If I ground it anywhere else on the car, the reading claims 0.00
So yes, about 0
Sorry, no it does not. I just did another few readings. This time 0.18. It was constant whether I had the key turned, or out completely.
OK great so we have our first point to rectify.
For the IGN, is there any other item that shares that fuse that is working, for example the cig lighter.
F10 5A Navigation computer/On-board monitor control unit/Radio control unit
Apparently no, so check fuse F10. Your multimeter has a resistance mode and a diode check mode, both can tell you if the fuse is in tact. Touch the probes together to understand how the display changes when the circuit is completed before you make your measurement.
Stock stereo now turns off as it should when keys are pulled. Something strange though (maybe I never noticed this) but I can STILL turn it on without the keys in. It is just that now if the radio is running when ignition is turned and I turn ignition off, the radio turns off as well.
If you are going to ask if it goes from ~12 to ~0 I was dumb and didn't check that, but can do if it would be helpful.
I would also like to thank you (and everyone else) for taking the time to help with this. It really is appreciated!
I wanted to update here!
The pioneer unit is working as intended.
Turns out my achilles heel was a pair of fuses. Sometimes it is the little things I guess!
THANK YOU EVERYONE FOR ALL THE HELP
It's alway seems to be the simplest things doesn't it?
That's why you're supposed to do basic diagnosing and problem solving before asking for help. Always check connections and not just with your eye but with a voltmeter. Honestly anyone doing any wiring whether it be soldering a new side marker socket to a stereo install should have a voltmeter handy. I used a voltmeter once when I was having major electrical issues. Systems shutting off while driving; gauges, lights ect, and found my car idling at 18 volts figured out instantly that my voltage regulator was out by a simple 18v car search on google. Had my car fixed the next day and never had to say a word to anyone. Now my radio is really acting funky with low reception when my lights come on. Been playing around and found nothing out of the ordinary and have done several searches and tried various solutions and still nothing. Our cars have a signal amplifier so I am thinking to replace that but want second opinions from people before I spend 200$.
Thanks again folks!
Quick question: I sort of didn't even think about this, but I lost steering wheel control functionality on the Pioneer unit. Not a HUGE loss since I only really messed with volume, for the most part, but is there a way to get this functionality back?
Thankful for the helpful and patient folks who were able to help me though, specifically joylove. I bet he was over there thinking "this idiot shouldn't even be replacing a bulb."
In any case, I learned a lot about my voltmeter yesterday! Thanks again folks!
What am I looking for on the box, manual, etc. to see if it does?
You're going to have to open up your steering column and cut a wire in it. Then connect that wire to the PAC adapter which then connects to your stereo.
Then you get the fun of programming it. Not too bad, but it seems to me it should take 3 hands.
If you go back in the thread, you will see that I didn't even really know how to use the tools I had correctly.
In any case, I learned a lot about my voltmeter yesterday! when you started messing around with the wires, had you disconnected the battery or pulled the fuses for the radio?
I'm guessing not, and you probably crossed something along the way and blew the fuses ... causing all your frustration.
Glad you are up and running.
You will need a BMW iBus to Pioneer remote adaptor for the MFSW buttons. the PAC-SW1 is a bit old now, in that it needs the programming to be done I think you can buy a pre-programmed unit, but i forget the vendor.
The more you know...
I just installed an Alpine head unit into my wifes MINI using the Crutchfield adaptor. The red wire they had me run into the fuse panel, connecting to the protected side of the wiper fuse. The radio would not turn on without this being connected.
Now I have the problem of the radio doesn't turn off with the ignition tho. It just stays on.
What fuse did you end up using so that your radio turns off with the ignition?
As you can see from the thread, I am by no means an expert.
Kind of strange that the kit would require you to tap into the fuse box, as mine didn't have it (and mine was just a $5 eBay deal).If you show a picture of your wiring, maybe simon here can better help you. Not promising anything from my end, but these other guys eventually got me sorted.
I guess I would need soemthing like this:
