Navigation + aftermarket radio question
Hi guys,
Can someone please tell me if it's possible to install a aftermarket radio unit with NAV + HK option? I think I saw a interface that would allow this but cannot remember what it was called or where it's located for purchase. Any help would be greatly appreciated. My car is a 2003 MCS. Thanks, Alex |
To use an aftermarket headunit with HK, you need an adapter called the HK Enabler. It is only sold by this UK vendor: http://www.newministuff.com/new/shop...uctshow&id=116. The website says they out of stock at the moment but you should check with them directly.
The issue with aftermarket stereos and Nav is integration of voice directions. The same UK vendor has an adapter but it isn't compatible with the HK Enabler: http://www.newministuff.com/new/shop...ductshow&id=51 |
Thank you so much for the information!!
