R53 HK System: Streaming Bluetooth Options
Hi Folks.
Just looking for your opinion and options that you may have tried personally or have heard of for the ability to stream music off my smartphone (lumia920) to my HK stock system via bluetooth?: Thanks :) SEN:thumbsup: |
If you have the aux jack there are several blue tooth receivers that plug into your 1/8th inch jack. Cheap and very easy to instal...
Yes...as pillagethesound said, you can get a bluetooth receiver for way cheap on ebay or amazon...less than $10 shipped.
http://www.ebay.com/itm/USB-Bluetoot...item27c999eaea I have one of these and it works pretty well....good sound quality too. The USB is just to power it, so you would need to get a cigarette lighter to USB adapter for it in your R53 (also very cheap). As already stated, you need to have an Aux input for your stereo. If you don't have one for the HK head unit, you can get one from Outmotoring or even your dealer for around $40....it plugs into the back of the stock head unit. |
Bluetooth via Ipod cable
I also have a R53 with the HK system with an Ipod aux cable. Will this work for bluetooth streaming?(http://a.co/d/2ru94au) Any one know? any other options other than a new system?
Originally Posted by lotter1
(Post 4435702)
The simplest way to get bluetooth streaming has already been mentioned — get an OEM aux input jack (https://www.outmotoring.com/mini-coo...p3_hookup.html) which plugs into the back of the radio. Then you can plug a bluetooth receiver into the aux input. You can get bluetooth receivers much smaller than the one in the earlier post. |
Originally Posted by rkw
(Post 4435719)
It might work, but it's hard to say because the OEM iPod adapter is such an odd device. The R53 headunit wasn't designed for iPods, so they created an iPod adapter that simulates a CD changer (there was a CD changer option). You would create special playlists on the iPod and the headunit could access them like CDs in the CD changer. If you plug in the device you linked, you might get sound out of it but there's a chance it could be incompatible.
A Grom BT3 is the best way to do this, without having to switch over to aux to use the phone and have the steering wheel buttons work, etc.
So does the GROM BT3 allow the existing steering wheel controls to work?
I have an 06 JCW with HK and an existing iPod 30 pin connector in the glovebox but the connector is crushed and I’m trying to decide the best way to get bluetooth into the car. Initially I was thinking I could just get a replacement cable and get one of these:
https://www.amazon.com/CoolStream-Bluetooth-Adapter-Volkswagen-iPhone/dp/B017RVHSSQ/ref=asc_df_B017RVHSSQ/?tag=hyprod-20&linkCode=df0&hvadid=312039478953&hvpos=1o1&hvnetw=g&hvrand=13768905933673962103&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=1014327&hvtargid=pla-571240283703&psc=1
. It states it works with the existing steering wheel controls on Mini and BMW. |
Originally Posted by Marine Blue
(Post 4465779)
I have an 06 JCW with HK and an existing iPod 30 pin connector in the glovebox but the connector is crushed and I’m trying to decide the best way to get bluetooth into the car. Initially I was thinking I could just get a replacement cable and get one of these: https://www.amazon.com/CoolStream-Bl...40283703&psc=1. It states it works with the existing steering wheel controls on Mini and BMW. |
Originally Posted by gumbedamit
(Post 4465838)
I use this unit https://www.amazon.com/gp/offer-list...&condition=new . No need to install in the boot, able to use the steering wheel control, no wires to run from the back of the car, and installs in 30 mins or less..... And, a lot less money
Thanks again. |
(Post 4465904)
Cool, thank you for the suggestion! That looks like it covers everything I’m looking for, I wonder why it didn’t pop up in my initial searches.
Thanks again. https://www.northamericanmotoring.co...ing-wheel.html |
Thanks for that link, that certainly helps.
Can the bluetooth module be located behind the headunit and or inside the glovebox? I really could care less about the other connections and only really want the music streaming and maybe the microphone for making calls. |
(Post 4465923)
(Post 4465923)
Can the bluetooth module be located behind the headunit and or inside the glovebox? I really could care less about the other connections and only really want the music streaming and maybe the microphone for making calls. I stuck all the extra cabling, mic, and bluetooth unit on the inside of the panel right under the steering wheel. You don't have to open this panel but I did it to help pull the bulky cable harnesses in the back of the head unit while i was reinstalling it so it made sense to hide everything there with some cable management and tape. I ran the included Aux cable to the passenger's side through the little opening next to the glove compartment in case I ever want/need it or the BT functionality breaks. It even clips into the built-in ?pen holder on the glove box door. |
Cleanest method is the GROM BT3. When I had my R53 that is what I used paired with the 07 Cabrio headunit.
I looked at the Grom unit, it's not cleaner. The unit I recommend plugs directly into the back of the existing head unit, no connection running from the CD Changer cable in the boot to the front of the the car.No wires to splice and works from the steering wheel controls. "Paired with your head unit". Do you already have BT stock on your R53?
If you've got an iPod adapter already you can just plug in a Bovee / Tune2Air device and it'll work mint. I bought one used on eBay for ~$30 and it's been working flawlessly - pairs as soon as you unlock the car, the steering wheel controls work perfectly.
(Post 4465838)
