does anyone know how to access the speed readout on the nav system? thanks!
What speed readout?
There's no way for the Nav system to display your current speed on it that I know of. It will only display what you have set as the "max speed" where a chime sounds when you exceed that speed... |
well, you can get a temporary read out. if you reset the average speed counter, it takes a reading of the speedo and averages it every second. so, the first few seconds, you can get a reading of what speed you're doing....of if you've got the cruise on or going the same speed, obviously this will last a little longer.
haf :smile: |
