Navigation & Audio Want to upgrade from Hi-Fi to Harman Kardon
#301
Yes but the pin configurations should be consistent for each type. Its just easier to deal with wire colors than tracing the pins.
Can someone tell me where the HiFi "amp" is located on a 2008 Clubman S? I have Sirius and DSC, so both underseat compartments are full and used, so location there even for a small 45x4 Class D is a no go. It would make more sense to replace the "HiFi amp" or put the Class D near it to take advantage if the speaker wiring.
I'll have to see where the IA system amp is installed for the HiFi upgrade.
#302
Yes, the pins should be the same. But given the connectors involved and the tight spaces they are in, having correct wire colors does make things much, much easier!
#303
#304
Is there any way to acquire the complete Harman Kardon wire harness loom for the entire system? I'm a new member here and I plan to try the base Boost stereo to H/K route but of all the parts, it's the wire that I could not locate part number anywhere. Any help is appreciated.
Thank you.
Thank you.
molala
10-02-2015 01:53 PM
