Navigation & Audio Change from miles per hour to kilometers per hour
Old Mar 9, 2009 | 02:36 PM
flavioleoni's Avatar
flavioleoni
Is it possible to change the speedometer (with NAV screen) from miles per hour to kilometers per hour? Is there a part number for that?
Tks.
Old Mar 10, 2009 | 10:26 PM
Topmini's Avatar
Topmini
im just guessing...
but i think u can maybe change it using the lever on the left of the steering wheel, and it will change it on the NAV too.
im guessing because i dont have NAV, all i got is normal speedo and changing it with the buttons in center console, or on the lever does the same thing.
Old Mar 10, 2009 | 11:08 PM
saturn's Avatar
saturn
I Think the OP is actually referring to the physical dial on the speedo? Yes??
If so, it requires replacing the whole unit.
Check here: http://www.realoem.com/bmw/showparts...88&hg=62&fg=05
Old Mar 12, 2009 | 02:33 PM
flavioleoni
Saturn,
That is correct. I would like to change the physical dial on the speedo. Tks a lot for the link.
Do you know if I can change only the "Instrument cluster" or do I need to change the the whole unit (including the Nav screen, which I believe wouldn't be necessary unless there is some sort of compability issue)?
Tks again.
Old Mar 12, 2009 | 03:39 PM
saturn's Avatar
saturn
That could probably be answered best by your local service department at the dealership.
Old Mar 13, 2009 | 04:04 PM
svtzx2's Avatar
svtzx2
Display is the same....just need to change the instument cluster.
Cereall
Sep 5, 2019 06:05 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
clintmeister
Aug 12, 2015 11:11 AM
