Navigation & Audio Best way to hook up 1 amp and two subs?
Old Nov 26, 2008 | 05:10 AM
n_wong89's Avatar
n_wong89
I was wondering what the best way to hook up one mono amp to two 4ohm subs. I want the most power getting to both of them. Whats the best way?
Positive output of amp to sub1 negative. Sub 1 positive to sub 2 negative. Sub 2 positive to negative output of amp?
Outputs from amp will be from just the left output? both? Confused! I just want the most power going to the subs, even if that means using just a left signal or just a right.
Old Nov 26, 2008 | 08:20 AM
schatzy62's Avatar
schatzy62
What make and model amp are you using?
It will make a difference as to how it needs to be hooked up.
Old Nov 26, 2008 | 10:19 AM
n_wong89's Avatar
n_wong89
Nothing fancy, but it does the job. used it in my other car but with only one sub.
''exile x400.1 mono amp''. 400 watts.
Old Nov 26, 2008 | 10:45 AM
schatzy62's Avatar
schatzy62
Per the manual this amp will take a 2 ohm load.
http://www.exileaudio.com/2007/manua...fiermanual.pdf
Se pages 3 and 6 for details on your specific amp.
As you have 2 - 4ohm subs you can just hook each one to the speaker block. positive to positive and negative to negative.
This will give you the best performance.
Old Nov 26, 2008 | 11:32 AM
n_wong89's Avatar
n_wong89
so...just using the positives as an example,
the the left sub positive will go to left output, and the right sub positive to the right output? or should they both come out of the same positive output?
(sorry i have just seen so many wiring methods)
Old Nov 26, 2008 | 12:13 PM
n_wong89's Avatar
n_wong89
or also is it better to wire these series or parallel?
http://www.caraudiohelp.com/ohms_law/ohms_law.htm i came across this site. my goal is to get loud, punchy base. (maximize power?). Which is better, why would you want a lower, or higher load.
What would you do? (in respect to the link diagram)
Old Nov 27, 2008 | 08:00 AM
pentavolvo's Avatar
pentavolvo
run both sub positives to positive output, and both sub negatives do negative output
this is parallel wirring, and 2 4 ohm loads in parallel is a fianl load of 2 ohms
gar56
Nov 15, 2016 06:41 AM
shadtree
Cooper (non S)
Sep 8, 2016 12:02 PM
pkillur
Sep 30, 2015 10:51 AM
