Navigation & Audio Short Antenna with Navigation
Old Nov 25, 2007 | 10:37 PM
minicobra1's Avatar
minicobra1
Anyone on here running a shorty antenna with factory navigation on an R56?
Is the receiver for the GPS in the base, and if so, will a short antenna affect reception? What brands are compatible? Thanks
Braden
Old Nov 25, 2007 | 10:56 PM
ScottRiqui's Avatar
ScottRiqui
Does the NAV-equipped R56 have the same screw-in mast antenna as the non-NAV version, or does it have one of those "shark fin"-type antennas?
If it has a mast antenna, you're probably safe replacing it. The GPS signal is at a frequency that's ten times higher than the highest AM/FM radio frequency, so I'd be very surprised if the NAV system depended on the radio antenna for anything.
Obviously, you'd want to leave the antenna base alone, and just replace the screw-in mast.
Old Nov 25, 2007 | 11:26 PM
minicobra1's Avatar
minicobra1
No, its def not a shark fin type, it looks to be a screw in type, I guess I should just try to unscrew it was afraid I might break something.
Old Nov 26, 2007 | 12:04 AM
Robin Casady's Avatar
Robin Casady
I'm running Craven Speed's Stubby (not the super stubby) with the factory NAV. No problem with NAV reception. Others have posted that the NAV antenna is in the base.
Old Nov 26, 2007 | 05:56 AM
djam43's Avatar
djam43
Yes the NAV element is in the base.
Old Nov 26, 2007 | 07:16 AM
lacning74's Avatar
lacning74
Like the sat radio antenna which people have been hooking up their external devices to, is there a NAV antenna pre-included in all cars. If so, could I hook up my Garmin Nuvi to it?
I just installed an external amplified Gilsson antenna. It definitely helps in urban jungles.
Old Nov 26, 2007 | 08:33 AM
minicobra1's Avatar
minicobra1
Hey Robin,
Thanks for the info, I just ordered it from Craven
Braden
Fordgt4
Oct 10, 2015 10:42 AM
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
pglgp1292
Oct 5, 2015 06:47 PM
simo711
Oct 1, 2015 05:36 AM
krohm
Sep 28, 2015 12:16 PM
