Navigation & Audio 02 cooper s aux input????
Old Jun 15, 2007 | 06:47 AM
wiseguy's02mini's Avatar
wiseguy's02mini
Can someone please tell me why the aux audio input will not work in the 2002 mini's???
wiseguy
Old Jun 15, 2007 | 06:59 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
The aux input will work in the 02 MINIs, but it depends on what build date you have. The early radio is not equipped for the aux input, but ones after August will have the newer radio in them and will work.
Old Jun 15, 2007 | 07:01 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
A change was made to the headunits for the '03 (10/02) and later years to enable the aux input function. While the connector is there for the aux, the internal workings were not enabled.
Simply swap your headunit with one from a later car. For '05 and '06, mp3 playback capability was added. There are lots of headunits available from people who have gone aftermarket. The swap is simple, nothing extra is needed.
Old Jun 17, 2010 | 05:53 PM
Hayden Henry's Avatar
Hayden Henry
Any suggestions for iPod hookup on models prior to October?
Old Jun 18, 2010 | 07:15 AM
plasticknives's Avatar
plasticknives
Blitzsafe BMW M.Link v1
http://enfigcarstereo.com/shopsite_s...MLINK1_V1.html
Utilizes the factory CD changer port and charges your iPod as well.
Old Jun 18, 2010 | 07:24 AM
Hayden Henry
How bad is installation on it?
Old Jun 18, 2010 | 07:27 AM
plasticknives
Pull off the removable panel on the passenger side of the boot, plug it in, done.
If you want a clean install you will need to pull back the side panel a bit and run the wire through it, otherwise you can just run it between the rear seats.
Old Jun 18, 2010 | 07:37 AM
Hayden Henry
Well im a tech retard so would some place professional be able to do it?
Old Jun 18, 2010 | 08:40 AM
plasticknives
Yes but there really is no need. It's 2 simple plugs.
Old Jun 18, 2010 | 09:09 AM
Hayden Henry
Well i'll purchase one and give it a go i guess.
Can you maybe provide some pictures?
Old Jun 18, 2010 | 09:19 AM
plasticknives
I was actually going to do that right after I posted but got side tracked lol
Here ya go (mounted with double sided tape)
Old Jun 18, 2010 | 09:25 AM
Hayden Henry
Thank you very much.
How long is the ipod cord it comes with?
Old Jun 18, 2010 | 09:26 AM
plasticknives
Not sure. I had it running through the panel, looped under the passenger seat a few times, then ending by the hanbrake.
Old Jun 18, 2010 | 09:31 AM
Hayden Henry
I think ive found a problem.
My MINI doesn't have the stock cd changer found in the panel.
So i don't have the plugs. :/
plasticknives
You have the plugs. Look harder
Old Jun 18, 2010 | 09:33 AM
Hayden Henry
Ill look.
what color are they? :b
Old Jun 18, 2010 | 09:51 AM
Hayden Henry
Well i took another look and i can't find any plugs except for the tail light and the trunk light. Everything else is just wiring. D:
Did you have to remove anything to find them?
Old Jun 18, 2010 | 11:00 AM
Pflashinaz's Avatar
Pflashinaz
Old Jun 18, 2010 | 11:56 AM
Hayden Henry
I'm 99% sure those plugs don't exist in mine.
I looked for an hour or so.
Also, my build date is 02/02
Old Jun 18, 2010 | 11:58 AM
plasticknives
Maybe the very first couple months didn't have it prewired for the cd-changer? I thought all Mini's were pre-wired. Mine is 04/02.
Old Jun 18, 2010 | 12:06 PM
Pflashinaz's Avatar
Pflashinaz
April of 02' marks the timeline when the first changes took place in MINIS. Perhaps this was one of them?
Old Jun 18, 2010 | 01:27 PM
Hayden Henry
Well my MINI is Feb 02' so its not prewired. :/
Old Jun 18, 2010 | 09:03 PM
JumpingJackFlash's Avatar
JumpingJackFlash
I used to have an 08/02 build '02 MCS, and I had the stock CD changer. To my best knowledge, ALL 1st-gen MINIs came with the plugs. They should be taped up if not in use.
StillK
R55 :: Clubman Talk (2008+)
Dec 7, 2022 08:19 AM
eliseo1981
Jan 28, 2021 02:45 PM
penguinhomey
38
Jul 7, 2019 09:24 PM
surfblue
Oct 24, 2018 01:20 AM
