Mini/MINI BUILDS Showcase your Build Talents.
R53 City/Backroad Build
Old Oct 16, 2024 | 07:02 PM
Woodymini7's Avatar
Woodymini7
Cool R53 City/Backroad Build
Hello all, I am going to start a build thread here for my 2003 R53 S 6sp.
It will keep me organized, but also hopefully provide some info through my trial and error, and some enjoyment throughout watching the progress.
I am starting from the basics with this build.
I purchased her in Indiana for 3k.
Has some cosmetic things, an unheard-of electrical issue, and basic maintenance items needed.
FEEL FREE to offer ANY suggestions, comments, opinions, or otherwise. Many specifics are not nailed down and are subject to change if you have a good idea. PLEASE provide your input if you would like to.
The Goal:
A murdered-out, Euro specific build that can do two things:
1. Be understatedly beautiful, able to be noticed on the street specifically by people with an eye for aesthetics, (not necessarily your avg tahoe-driving Joe), as well as hold it's own if it decides to turn up at a show.
2. Can be driven "hard", (depends on your definition I guess, but I tend to ask a lot from my cars) with a balance of comfort for city streets, and a surplus of performance for ripping around backroads.
Priorities:
1. The unheard-of electrical issue. I found a couple threads with some suggestions in Mini2 that I will be trying, but no one on the entire internet has had this problem apparently. (Periodically, if I go over a bump in 4th-6th gear, the Engine light, EML light, DSC light, Tire Pressure light all come on and the temp gauge spikes to the top where the gauge light comes on, it goes out of gear, and will not return to gear for a second or three, sometimes longer but not usually. While it is coasting, I can then clutch, shift, and everything returns to normal like nothing ever happened. Until another random bump ofc. Occasionally the DSC and TP light will stay on, but not usually. I know, weird right? It has me and my dope asf car guy, Matt @ Grossman Tuning, scratching our heads.)
2. She needs a new hood, as this one is damaged on the right side.
3. I must run windshield and headlight washer lines, as they are not hooked up.
4. Needs paint repair on the drivers side.
Suspension/Wheels/Tires:
1. Winter tires are my next purchase, as these are shot and winter is approaching quickly in Louisville where I reside. They will go on my stock R85 wheels, which are silver, and that will be my permanent winter setup. Since winters can get salty and rough around here, it will not necessarily match my desired murdered out setup. (At most, I might plastidip the wheels if the silver bothers me too much). OPEN to suggestions for winter shoes, as I have not decided on anything yet.
2. Adjustable Rear Control Arms.
3. Coilovers. I need something that will lower her a bit, successfully balances comfort with handling, and has adjustable camber and damping. Leaning heavily toward KW. Probably V2 from what I have seen.
4. Rear sway bar.
5. Summer shoes. Black, 17x7.5 and 215/45s.
6. Brake upgrade.
Performance:
1. Coil Packs and Wires
2. Full Exhaust system. (have not decided yet, open to suggestions)
3. CAI
4. 15% SC Reduction
Exterior:
1. Claybar
2. Underbody protection
3. Chrome delete
4. Smoked lights
5. Darker tint. (I know, I like it dark asf)
6. Splitter and sideskirts. (Will also entertain spoilers, but I rather like the current understated stock spoiler).
Interior:
1. New Steering wheel
2. Sound foam in doors and under seats.
3. Interior lighting
If I am careful, I am pretty sure I can get out for under 10k. The coilovers, new shoes, and exhaust system are gonna be the heavy hitters for sure.
I am thinking about the time I have her looking the way I want, it will be time for a new engine. Hence the small Performance upgrades, everything can be moved.
Again, PLEASE provide your input if you would like to. Many specifics are not nailed down and are subject to change if you have a good idea.
Also if you are near Louisville, KY, whether you have parts that could help my project, or just to hang or go for a drive, hit me up.
I hope this thread can provide you some enjoyment also, as it will definitely be fun for me to do this.
Cheers!
Old Oct 16, 2024 | 08:32 PM
MCS4FUN's Avatar
MCS4FUN
Although somewhat similar end objectives, I went a different route by buying one with super low mileage and condition, highly modded, which then needed "taming" for practical streets and highways usage (no tracking). Be careful on mission creep WRT stated all-in budget. Mine did so but with desire to buy new parts aligned overall with my R53 and ended up with a total spend representative of that. Rather than the blacked-out look with bodywork add-ons, my preference is a more stealthy appearance. Mine looks pretty much stock on initial glance, until noticing aspects which reveal quite the contrary. Looking forward to future updates...
Old Jan 7, 2025 | 05:58 AM
JerBear's Avatar
JerBear
I'm subscribing mostly to follow. Like you I HATE chrome. The previous owner of my 05 R53 had started blacking it all out and plasti-dipped a bunch of random parts. My suggestion is don't. It looks like crap and doesn't hold up. You can buy pretty much all the little parts in black or carbon fiber. Go that route, you'll be happier.
For wheels, I don't personally like the way 17's ride. Mine came with 17's and I hated them. I swapped them for a set of 15's off my other mini but they are a little small. I think 16's are the perfect size both in appearance and weight/handling.
Looks are very subjective though so if your really stuck on 17's find the lightest wheels you can. Unsprung and rotational mass make a big difference on these cars.
Can't help you with suspension. I put a 19mm eibach on both mine and am very happy. I like a balanced car though on the street, not into a ton of oversteer. KW V2 are extremely popular for coilovers, koni yellow seem to be at the top of the list for a more factory style setup. Mine was purchased with Racelands on it and they are about the worst riding noisy pos I've ever experienced. I HATE them. I had a Tein/Bilstein combo on the last car and it was a little stiff but really almost epic for hooning on a budget.
If I can I want Koni strt with eibach coils. I've ran that setup on other cars and it was about perfect for the street. Can't fine tune ride height but I DD mine and don't care.
Welcome aboard if this is your first mini and enjoy the ride!
Old Jan 16, 2025 | 08:38 AM
Woodymini7's Avatar
Woodymini7
Time to go
Hello all, sorry to stop this build short, but with a child on the way, I need 4 doors and room for a carseat and stroller, so unfortunately need to part with this girl, for another one. (or boy, idk yet lol)
I am happy with this trade though, ready for a new chapter.
Anyways, here is the For Sale Thread with all the current details: https://www.northamericanmotoring.co.../market/370466
Northern
Mini/MINI BUILDS
38
Sep 3, 2025 09:00 AM
TIRESONFIRE
Mar 19, 2024 11:45 AM
jamez
Suspension
11
Apr 11, 2020 04:50 PM
Dogote
Aug 26, 2016 12:00 PM
TheBigChill
Jun 1, 2015 07:13 PM
