Slightly used, great price.
Absolutely nothing wrong with them, just went to a different size. Fronts are about 85-90% there, Rears abour about 99%. They were over 400 new, I'll take 200 (OBO)! I'm NUTS I tell you, NUTS! :grin: They're sitting in my garage taking up space. Please note that it's probably not worth it to ship them so I would consider offers relatively close to my location in Madison, WI. I'll drive to meet you if it's within reason. So you tell me where you live and I'll tell you if it's within reason. :lol: PM me here or send e-mail to jayoung@mailbag.com Thanks for your interest! -Jim |
Darn it! I'm looking to buy a set but am too far away in Alabama.
Someone will snap these up! |
^^^what he said (just add NY) :cool:
Let me guess, you're getting a little rubbing on the rears, right?
I have the H sport springs and the same tires... |
>> >>I have the H sport springs and the same tires... >> will the 215's rub with stock springs? :cool: |
>> >>I have the H sport springs and the same tires... >> >> Nope! I had 225's on and they rubbed but not the 215's. Scout's honor. -Jim |
>>>> >>>>I have the H sport springs and the same tires... >>>> >> >>will the 215's rub with stock springs? > :cool: Mine didn't. I think it depends a lot on the offset. Ask around, lots of people have run them. -Jim |
is schaumburg close enough? :smile:
If so, I'll take it. :grin: |
>> >>If so, I'll take it. :grin: Ken: Left you PM. -Jim |
>> >>If so, I'll take it. :grin: your in the schaumburg area?!?! i am close to ya then...im in glendale heights. p.s. sorry for hijacking this thread. -chris |
Yep, let's do a mini-MINI-meet sometime. :smile:
>>>> >>>>I have the H sport springs and the same tires... >>>> >> >>will the 215's rub with stock springs? >> :cool: NO, I have 215/40ZR-17 AVS ES100 and NO problem = had Ace Alura 17-7.5 now have SSR comp 17-7.5 with same tires (just new ones). MCS Earl |
>> >>I have the H sport springs and the same tires... >> >> Yup mine (215/45R17) rubbed with stock springs, rim offset is 42, but only on a harsh bump, not during normal driving (but who does that). After a few miles and a rotation all OK. |
>>>>>> >>>>>>I have the H sport springs and the same tires... >>>>>> >>>> >>>>will the 215's rub with stock springs? >>>> :cool: >> >>NO, I have 215/40ZR-17 AVS ES100 and NO problem = had Ace Alura 17-7.5 now have SSR comp 17-7.5 with same tires (just new ones). >> >> 10851CS....what is the rim offset on your wheels? gotta check my offset......smokey4 says they rub with a rim offset of 42 any help on this would be greatly appreciated i have to order tires in the next couple of weeks :cool: |
>> >>gotta check my offset......smokey4 says they rub with a rim offset of 42 >> >>any help on this would be greatly appreciated >>i have to order tires in the next couple of weeks >> :cool: What I've been told is that you need a 42mm offset or higher and the factory S-Lites are a 50mm offset. -Jim |
>>What I've been told is that you need a 42mm offset or higher and the factory S-Lites are a 50mm offset. >> so a 44 or 48 offset would work with the 215's without rubbing? :cool: |
>>>>What I've been told is that you need a 42mm offset or higher and the factory S-Lites are a 50mm offset. >>>> >> >>so a 44 or 48 offset would work with the 215's without rubbing? >> :cool: Yes. This is according to Tire Rack. |
Mjolnir.....thank you
i should of just asked the guys at the Tire Rack (that's where i order my tires from anyway) :cool: |
Hey Kool,
Unless I'm reading this wrong 10851CS has 215/40ZR-17 AVS ES100 I have 215/45ZR-17 and when I was specing this setup out with Alex @tirerack and also Joe @Rspeed both said that the 42 offset was perfect. The rubbing I experienced wasn't caused by the tire hitting any portion of the suspension, it was the outer edge of the tire hitting on the wheel spat inboard edge. And like I said after about 1000 miles and one rotation I don't get any rubbing. |
how do you determined the offset of the wheel?
is it the backspace? i measured the back space of the rim (5 1/2 inches) :cool: |
>>is it the backspace? >>i measured the back space of the rim (5 1/2 inches) >>:D :cool: It will be (should be) stamped on the inside of the wheel. -J |
^^^^^^Mjolnir
i looked, but the stamped stuff didn't look like offset numbers i don't know what it was? so i measured the back space thinking that the offset was the same thing but when i converted from inches to mm, it didn't make sence :cool: |
>>is it the backspace? >>i measured the back space of the rim (5 1/2 inches) >>:D :cool: The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. Lots more stuff Here |
Mjolnir,
Are those yoko's still available? If so I'm interested. Although I'm in Fl., I have a driver who is going to be in Milwaukee next wk to pick up an 04 MCS we bought. If possible, could you get them over there or is it too far. Let me know I don't have a lot of time before he leaves. Thanks Craig 03 MCS Blk/Blk, Alta intake, pulley, madness bar, voghtland springs. Pilo coil, magnacor wires. Helix short shifter, Borla Sport, Alta Diverter |
>>Mjolnir,
>>Are those yoko's still available? If so I'm interested. Although I'm in Fl., I have a driver who is going to be in Milwaukee next wk to pick up an 04 MCS we bought. If possible, could you get them over there or is it too far. Let me know I don't have a lot of time before he leaves. >>Thanks >>Craig >> Thanks to all of you were were interested in the tires, but I sold them today! -Jim |
| All times are GMT -7. The time now is 07:39 PM. |
