Marketplace - Archive Old Marketplace threads and posts (Read-only). Please use appropriate Marketplace forum for new posts.
Amsoil XL-7500 5W30 - For those who change oil often.
Old Aug 16, 2003 | 06:57 PM
Zappa's Avatar
Zappa
One of Amsoil's newer lines is their XL7500 series. These do not contain the more expensive addities and dispersants and have a lower TBN for short term use. So if you change oil at intervals less than 10,000 miles this one is for you at an incredible price.
These are designed for a guaranteed 7500 mile oil change and is the AMSOIL product most service centers use. The AMSOIL XL-7500 is 100% PAO synthetic. (Polyalphaolefins)
For the remainder of this month I will sell these for $50 for any one case or $45.00 for any two cases which breaks down to $3.75 each quart. Take your pick, 5W20, 5W30, 10W30 and 10W40.
ORDER HERE.
Here is a summary of the product:
Synthetic XL-7500 Motor Oils
AMSOIL XL-7500 Synthetic Motor Oils are specially formulated to provide outstanding wear protection, power, fuel economy and performance for 7,500 miles or six months of service. With AMSOIL XL-7500 Synthetic Motor Oils, motorists driving 15,000 miles a year need only change their oil twice annually. AMSOIL XL-7500 Synthetic Motor Oils offer a high degree of convenience and savings through their ability to perform and protect engines for extended periods
PRODUCT DESCRIPTION
AMSOIL XL-7500 Synthetic Motor Oils are specially formulated to provide outstanding wear protection, power, fuel economy and performance for 7,500 miles or six months of service. With AMSOIL XL-7500 Synthetic Motor Oils, motorists driving 15,000 miles a year need only change their oil twice annually. AMSOIL XL-7500 Synthetic Motor Oils offer a high degree of convenience and savings through their ability to perform and protect engines for extended periods.
Thermal and Oxidative Stability
AMSOIL XL-7500 Synthetic Motor Oils eliminate the need for frequent oil changes. Outstanding thermal and oxidative stability ensures long- term physical and chemical integrity of the oils after exposure to engine operating temperatures.
Low Volatility
Low volatility makes AMSOIL XL-7500 Synthetic Motor Oils highly resistant to oil consumption. The oils continue to lubricate, maintain fuel economy, and reduce exhaust emissions for an extended drain interval.
Shear Stability
Superior shear stability ensures AMSOI L XL- 7500 Synthetic Motor Oils maintain protective viscosity throughout extended service life. The oils continue to protect engine components from metal-to-metal contact and wear, especially in high temperatures.
High Temperature Performance
AMSOIL XL-7500 Synthetic Motor Oils offer outstanding high-temperature engine protection and performance. Engines operate in optimal temperature range in high-stress conditions. In high-temperature operations, AMSOIL XL-7500 Synthetic Motor Oils provide clean, dependable lubrication and protection.
Low Temperature Performance
Wax-free synthetic stocks ensure the rapid flow of motor oil throughout the engine after startup, protecting engines from wear. AMSOIL XL-7500 Synthetic Motor Oils' low temperature fluidity also helps engines start dependably year-round and significantly improves cold temperature fuel economy.
Fuel Economy and Power
AMSOIL XL-7500 Synthetic Motor Oils enhance fuel economy and powerful performance. Low coefficients of friction ensure the maximum delivery of engine power with minimal frictional losses.
Corrosion, Rust and Foam Control
AMSOIL XL-7500 Synthetic Motor Oils seal out rust, neutralize acids and resist foaming. Rust inhibition is an especially important feature for engines subject to frequent short-trip operations or for stored engines. Acid neutralization protects engines from damage caused by corrosive by-products of combustion. Foam resistance ensures protection against metal-to-metal contact and wear.
Additive Durability
AMSOIL XL-7500 Synthetic Motor Oils contain top-quality additives designed for long-term performance. AMSOIL XL-7500 Synthetic Motor Oils protect engines from wear, corrosion, deposit accumulation and sludge buildup. The long-life additives in AMSOIL Synthetic XL-7500 Synthetic Motor Oils are designed to keep engines clean and protected for 7,500 miles or six months, whichever comes first.
Meets or exceeds the following specifications for domestic and foreign gasoline engines:
5W-20 5W-30 10W-30 10W-40
API SL, SJ
ILSAC GF-3, GF-2
Ford WSS-M2C205A, M2C153G
GM 4718M
Chrysler MS 10440, MS 6395H
ACEA A1, B1
JASO VTW
API SL, SJ
ILSAC GF-3, GF-2
GM 4718M
Chrysler MS 10441, MS 6395H
ACEA A1, B1
JASO VTW
API SL
SAE J300
ILSAC GF-3, GF-2
GM 4718-M
ACEA A1, B1
JASO TW
ILSAC GF-3, GF-2
Ford WSS M2C153H
ACEA A1, B1
JASO VTW
API SL, SJ
ILSAC GF-3, GF-2
GM 4718M
ACEA A1, B1
JASO VTW
API SL, SJ
ILSAC GF-3, GF-2
GM 4718M
ACEA A1, B1
JASO VTW
API SL
SAE J300
ILSAC GF-3, GF-2
GM 4718-M
ACEA A1, B1
JASO TW
MIXING AMSOIL
AMSOIL XL-7500 Synthetic Motor Oils are compatible with conventional petroleum oils. However, AMSOIL does not recommend using a mixture of XL-7500 oils and conventional oils for 7,500-mile or six-month drain intervals. Engine oil additives are not recommended for use with AMSOIL XL-7500 oils.
SERVICE LIFE
In gasoline-fueled passenger vehicles in normal or severe service, change AMSOIL XL-7500 Synthetic Motor Oils at 7,500-mile or six-month intervals, whichever comes first.
Change aftermarket or OEM full flow oil filters with every oil change.
Premium quality AMSOIL Full-Flow Oil Filters are recommended for use with AMSOIL XL-7500 Synthetic Motor Oils, and may be used for 7,500 miles or six months, whichever comes first.
TYPICAL TECHNICAL PROPERTIES (Revised 4/03)
AMSOIL XL-7500 SYNTHETIC MOTOR OILS 5W20 5W30 10W30 10W40
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 8.9 10.3 10.2 14.5
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 45.0 50.9 59.0 80.9
Viscosity Index (ASTM D-2270) 183 196 163 178
CCS Viscosity, cP @ (°C) (ASTM D2602) 3670 (-30) 2320 (-25) 2300 (-20) 4951
Flash Point °C (°F) (ASTM D 92) 229 (444) 234 (453) 229 (444) 232 (450)
Fire Point °C (°F) (ASTM D 92) 242 (468) 250 (482) 242 (468) 248 (478)
Pour Point °C (°F) (ASTM D 97) -46 (-51) -51 (-60) -43 (-45) -42 (-44)
Noack Volatility, % weight loss (g/100g) (DIN 51581) 8.2 8.8 4.7 5.6
High Temperature/High Shear Viscosity @ 150°C and 1.0 X 106 s-1, cP (ASTM D4683) 2.9 3.1 3.2 3.8
Four Ball Wear Test (ASTM D 4172 @ 40 kgf, 150°C, 1800 rpm, 1 hour, Scar in mm)
0.38 0.38 0.38 0.38
Total Base Number (ASTM D2896) 10.2 10.1 10.2 10.2
_________________
</p>
<a href="http://www.syntheticwarehouse.com">AMSOIL - Official Synthetic for MCO and Team MCO
DixonL2
Apr 13, 2021 08:05 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Lex2008
Aug 16, 2015 08:33 PM
FLYM1N1
Aug 16, 2015 01:17 PM
minipopkart
Aug 13, 2015 05:22 AM
