OEM 2006 R53/R52 shifter assembly - modded with complete B&M Short Shifter Kit
Old Dec 10, 2023 | 05:16 PM
  #26
MCS4FUN's Avatar
MCS4FUN
Back up to page 1...
Old Dec 25, 2023 | 06:58 PM
  #27
MCS4FUN's Avatar
MCS4FUN
Back to top...
Old Jan 8, 2024 | 07:53 AM
  #28
MCS4FUN's Avatar
MCS4FUN
^^^ Bumpity-bump -- make an offer...
Old Feb 1, 2024 | 07:17 AM
  #29
MCS4FUN's Avatar
MCS4FUN
Back to top, noting a much better deal here than on my eBay listing...
Old Feb 2, 2024 | 10:40 AM
  #30
OutlandishnessDue's Avatar
OutlandishnessDue
Curious - why would this have more cabin noise that a stock shifter? Just noticed this in the comments.
Old Feb 2, 2024 | 11:08 AM
  #31
MCS4FUN's Avatar
MCS4FUN
The OEM shifter with Short Shift Kit installed doesn't increase cabin noise. Instead, an SSK kit's extended shifter box reduces the required clearance for an exhaust resonator. It's the header with high flow cat that increases cabin noise which a resonator attenuates, thus my removal of the SSK. Clearer now?
Old Feb 3, 2024 | 08:15 AM
  #32
OutlandishnessDue
Thanks - my Invidia is resonated as well so this is likley a no go.
Old Feb 3, 2024 | 08:35 AM
  #33
MCS4FUN's Avatar
MCS4FUN
Depends on resonator diameter Invidia uses, which appears to be smaller OD bullet style vs canister. Mine is Milltek which required more clearance to the B&M's extended enclosure.
Old Feb 3, 2024 | 08:43 AM
  #34
MiniManAdam's Avatar
MiniManAdam
Community Builder
I'm running nvida with a coolerwox shifter which has a LONGER shiftbox..
it fits , it absolutely fits.. you can get more clearance by manipulating the heatshielding in the tunnel area by the shifter and resonator..
even befor I did that , the ONLY issue i got was the shifter got a little warm because it sat so close to the exhaust resonator. Not nearly hot enough by anymeans to cause any damage or issues but I deleted my ac ect so I needed to keep it cool as I could inside...
I hope this help...
Old Feb 24, 2024 | 06:20 PM
  #35
MCS4FUN's Avatar
MCS4FUN
Bump up to the top...
Old Mar 8, 2024 | 06:04 AM
  #36
FXLRS~R53's Avatar
FXLRS~R53
Is there a threaded adapter for other shift *****?
Old Mar 8, 2024 | 08:04 AM
  #37
MCS4FUN's Avatar
MCS4FUN
The B&M shift lever uses same style bifurcated (split) design to accommodate the OEM shifter ****. I used a much heavier Raceseng **** with their application-specific threaded adapter on the OEM/B&M combo, which I continue to use on the donor shifter with great satisfaction.
Old Mar 8, 2024 | 08:45 AM
  #38
FXLRS~R53's Avatar
FXLRS~R53
I have a custom made shift **** that's internally threaded, so I am just trying to figure out if I could use it with this shifter. It was made from a local 3d printing company with M12x1.25 threads
Old Mar 8, 2024 | 09:24 AM
  #39
MCS4FUN's Avatar
MCS4FUN
Raceseng ***** are internally threaded 3/4-16, however if the adapter you have slips over the OEM or aftermarket shaft, your **** and adapter should fit fine since its the shifter shaft outer diameter that is critical to adapter suitability.
On my original Raceseng order, I goofed with this P/N whereas what I needed was this P/N with slip-on design and set screw, noting both designated for Raceseng's 3/4-16 **** thread pitch.
Old Mar 26, 2024 | 11:27 AM
  #40
MCS4FUN's Avatar
MCS4FUN
^^^ btt ^^^
Old Mar 26, 2024 | 03:55 PM
  #41
WGJP's Avatar
WGJP
With so many bumps to the top since your "last bump" six months ago, it might be time to revisit your dynamic pricing algorithm.
Or donate it to a 501(c)(3), take the tax write-off and be done with it. Kars4Kids?
Good luck with final final final sale.
Old Mar 26, 2024 | 05:23 PM
  #42
MCS4FUN's Avatar
MCS4FUN
^^^ Um, thanks for that suggestion...
This hybrid assembly doesn't suit every 1st Gen fitment or NVH objective thus remains unsold for that reason vs price.
Old Apr 13, 2024 | 05:21 PM
  #43
MCS4FUN's Avatar
MCS4FUN
Still available here and on eBay and yes, open to reasonable offers.
A great shifter assembly for those wanting "the total package".
