JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
316mm rotors on R52, mounting bkt extensions needed?
Old Nov 26, 2022 | 04:39 PM
Eddie Vergara's Avatar
Eddie Vergara
Folks,
Have done my fair share of searching on this and other forums, can't seem to get to a specific answer to my question: Can I install the R56 JCW calipers on the R52 while also installing the 316mm front and 280mm rotors?
Some kits like the Brembo and Wilwood BBKs include mounting bracket extensions. I'm curious if these are needed also if installing the R56 JCW stock calipers along with the 316mm rotors.
I have the R56 rear trailing arms, so my concern is more regarding the front rotor size (316mm) fitment on the R52.
Thank you for any two cents.
Old Nov 26, 2022 | 05:01 PM
jcolletteiii's Avatar
jcolletteiii
See my topic on the Budweg remanufactured R56 JCW (Brembo) calipers. No bracket is needed if you're using the JCW 4 piston Brembos. Bolt up the caliper, the 316x22 disc, and a set of R56 lines. Wheel choice, however, is another topic. I doubt even that all 17" wheels will even fit with this conversion. 16" wheels are a definite no-go.
Old Nov 26, 2022 | 05:14 PM
Eddie Vergara
Planning on running on R136s... currently using R90s. Both seem to be okay with the BBKs.
Thanks for the confirm.
Tim McCreary
Nov 12, 2017 02:21 AM
texasmontego
Tires, Wheels, & Brakes
Aug 16, 2011 10:06 AM
Mini_Chan
Aug 25, 2010 05:03 AM
STLMINI
Sep 20, 2007 01:53 PM
