F55/F56 JCW pro exhaust tips on stock JCW exhaust?
Old Jul 1, 2020 | 06:18 AM
islandguy808's Avatar
islandguy808
2 questions:
A) is it a faux pas to put carbon fiber tips on the stock jcw exhaust just for aesthetics? I just don't like the look of the chrome tips.
B) how do you remove the existing tips?
Old Jul 2, 2020 | 11:51 AM
curlywurly's Avatar
curlywurly
I believe the full MINI P/N for these is 18302349677
Inside diameter is 68mm for that part # - and is intended, along with the polished SS version - as part of the PRO exhaust system.
I do recall threads of users on here that have successfully put the tips on the non JCW pro exhaust as you are asking
I also see on the newest configurator (for Mini Canada) there is now an option to spec. the CF tips to a stock car (ie non JCW pro valved exhaust).
(image from configurator below)
So - looks promising for you. Double check see if there are two P/Ns for different diameters - or if the one quoted above at 68mm works.
Old Jul 2, 2020 | 01:27 PM
islandguy808
I've read that the original tips are spot welded on. And I've read that they're not. That its held on by a clip or something. Can anyone confirm what is correct?
Old Jul 2, 2020 | 02:01 PM
robby71's Avatar
robby71
I believe you can tap them off using a piece of wood and a mallet - the round thing in the photo above is a locating pin which the slot in the trim locates into
Old Jul 2, 2020 | 02:12 PM
curlywurly's Avatar
curlywurly
Seems to be more guys from Britain doing this - try the f56 board to ID how to remove the old ones.
The user 'killalchrome' has a lot of action. His vid here covers the install - havent watched it so not sure if he addresses the spot weld/clip issue;
Old Jul 2, 2020 | 02:16 PM
robby71's Avatar
robby71
The tips they sell are the same ones for 1/2 the price on Aliexpress
Old Jul 2, 2020 | 06:18 PM
hcube's Avatar
hcube
I bought the Countryman tip which is bigger than Hardtop and you can just slide them over the existing tip.
Old Jul 3, 2020 | 03:53 AM
islandguy808
I got my CF tips on Ebay used for 1/2 price as new. I was SO excited to put them on but can't get the original tips off!
Old Jul 3, 2020 | 10:41 AM
curlywurly's Avatar
curlywurly
https://www.minif56.com/threads/exha...56-mini.33665/
Old Jul 3, 2020 | 01:39 PM
rbm416's Avatar
rbm416
Yes, it is a faux pas. Just like putting JCW stickers on a justa. Go all in or don’t do it at all.
Old Jul 3, 2020 | 06:24 PM
Agbullet25's Avatar
Agbullet25
The JCW Pro exhaust tips are a bigger inside diameter than the factory JCW exhaust, so while technically it can work, it's not flush and doesn't look 100% right.
Kitchenboy
May 20, 2020 02:35 PM
SandroPT
Jun 12, 2019 07:08 AM
Mike r56
Jun 7, 2016 12:14 PM
ngweibing
Aug 26, 2008 10:32 AM
