Has anyone replaced stock battery with a Braille21 Lightweight battery?
Old Aug 8, 2019 | 01:16 PM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
Just wondering if anyone has done this and if it was pretty simple to do...trying to lighten up the front a bit...this battery is less about half the weight of stock battery...
Smaller and lighter...will probably line the interior box with lightweight foam to help hold battery in place...will see what works best when changing it over.
Old Aug 8, 2019 | 01:22 PM
sub3622's Avatar
sub3622
I have the 17lbs in my r56 and it works really good. No problem at all. They also sell accessories to hold the battery in place.
Old Aug 16, 2019 | 08:40 AM
663's Avatar
663
i use the Voltphreaks VPR-P6. 6lbs, auto-shut off for low voltage conditon; on/off switch. held in place perfectly with a Rennline kit. i also removed the factory battery box for better air flow in the engine bay....air exhausts up and out by the windshield
Old Aug 16, 2019 | 11:41 AM
Darbys2019MiniJCW
I am adding the NM Strut Brace and thought about removing the Rubber Gasket along the top side of the engine bay across the windshield to get better airflow...
Racing this weekend at COTA (Circuit of the Americas)...AutoX
Battery after this weekend...some form of lighter battery and setup
Note: I really do think that relocating a super light battery (lithium) to the rear area would be most beneficial...just don't know about $1K+ for a battery...plus cables and tie down apparatus...
Old Aug 17, 2019 | 05:28 AM
663's Avatar
663
I have the NM as well and removed the gasket....it does improve air flow out of the engine bay.
There is plenty of room in the rear for a battery, but the weight of the cables would work against the concept. Coil overs are a more effective means of influencing weight distribution. And, my caster/camber adjustable Nitrons just showed and replace the V2’s next week! Booyah
Old Aug 17, 2019 | 02:29 PM
Darbys2019MiniJCW
Battery is going to stay up front....will probably go with a Braille B3121 at 21 pounds...maybe...??? I did remove the gasket
SlothsRUs
Nov 8, 2017 08:15 AM
Wanderlustsrt
Jan 31, 2017 04:05 PM
EllaJeanLumpkins
Electrical
Mar 10, 2009 04:41 AM
royce
SCCA Solo and ProSolo
Oct 25, 2005 11:14 AM
