Air Filter Opinions
Hello JCW guys (and gals?),
I am looking to put a better flowing air filter in my 06. I was wondering if anyone has an opinion on the Pipercross air filter that ECS sells. I looked them up and they seem to have a pretty good racing pedigree. I have been looking on the site and I can't find anyone who offers an opinion on the brand. I have also looked at the Amsoil, K&N, and Alta. I like the double layers of the Pipercross. Has anyone used, or is using, the Pipercross filter? |
I have no opinion on your request, but it is not a great idea to use any oiled air filter, as the maf will get clogged with dust and cause codes and power issues.
So whatever system you go for, get the dry type filter! |
Pipercross has been used on MINIs since back in the early MINI challenge days of Gen 1s, they are a very light oil foam filter compared to other oiled filters. I have not really heard any MAF issues with those, Just watch how you oil the filter, I have the JCW factory sound kit from MINI for my R52 that has a BMC factory oiled filter. Thats correct MINI had an oil filter from the factory for that kit. You have to watch not to over oil the filter.
More info here: https://www.northamericanmotoring.co...enge-cars.html https://www.northamericanmotoring.co...ir-filter.html https://www.northamericanmotoring.co...all-of-it-.jpg |
most things are a OK in moderation
It is so easy to being dogmatic and that including unfound opinion on oiled filters. Certainly too much oil in the intake tract is seldom a good thing. But your unadulterated Mini intake track is never oil-free. Properly oiled, oiled air filter should not cause problem as there is more oil introduced by the PCV alone. I would advice to stay away from any foam type filter however unless you are very vigilant with the condition of the air filter. Most foam element fail in a rather catastrophic manner, and bits of foam is not a diet your Mini's engine appreciates.
Thanks for all the advice. I wasn't sure what kind of flow Minis like. I have Fabspeed filters on my 930, they are similar to K&N and the engine loves them. My 67 has a draw through turbo with a Holley 650cfm on top. I found that set-up ran better with a single layer dry foam filter, rather than a K&N. With the small displacement of the Mini's 1.6 and the rather small volume of the intake manifold, I was wondering if the engine would prefer a more "restrictive" filter. I just want to avoid flat spots in lower RPMs. I have never had a supercharged engine before, just turbos!
Originally Posted by pnwR53S
(Post 4437094)
Never had an issue with K&N filters from the oil. Not really all that difficult to judiciously apply the oil after cleaning. Now that being said, don't really think they do much for performance. They claim up to 4 hp, I'd love to see the hoops they went through to prove that.
Currently using an AFE dry filter, makes me feel better, doubt it does anything performance wise. I didn't pop the filter in and go wow, we are really moving faster than ever. |
We've used the pipercross and other foam filters like the ITG and frankly they just fall apart over time so I recommend avoiding them.
Since you just want a stock replacement filter I'd go with the Afe Dry filter https://www.waymotorworks.com/dry-pa...-cooper-s.html My second option would be the K&N filter https://www.waymotorworks.com/k-n-dr...-cooper-s.html |
Well, if the Pipercross filters fall apart, I definitely want to stay away from that!
I looked at some import racing websites and people are using Amsoil filters on a lot of different builds, both forced induction and natural aspiration. That seems like a pretty good endorsement to me! I have decided to go that route. Unfortunately, neither ECS or Way Motor works sells it. I'm going to have to get it from Detroit Tuned. Hate to not support our sponsors... |
Do these upgrades have an advantage over the OEM filter? I just replaced mine with stock, but I have a base engine.
If using a high quality foam filter, it is imperative that you clean it with the method and cleaning agent specified. To do otherwise will cause the element to disintegrate.
Originally Posted by Jaughn
(Post 4437229)
I run K&N filters on almost everything I own and plan to keep, including a K&N inside the JCW airbox on my R53. I've never had any trouble with them on all kinds of motorcycles and cars/trucks. It becomes economical after a while, I just keep buying the cleaner and oil for all my vehicles. |
I use a K&N drop in panel filter too. I know there is the oft stated worry about oil. But I haven’t had any issues which any car with a K&N filter. As said above, economics plays a part, because you only have to buy the filter once. And I already have several sets of cleaner and fresh oil. You do want apply the oil sparingly, for sure, but that’s kind of common sense. My Mini does breathe a bit better with it over stock, but no real noticeable difference in power or anything really. Just my wallet mostly. |
Thanks MrG for answering my question. When you say it breathes better, what attribute can you detect? Sound? RPM?
I also like the idea of not having to shell out $35 for a filter every 20K miles. |
Derek86,
I had no idea about Fabspeed using Chinese knockoffs!!! They are a favorite of the Porsche Club in Orlando...I bought quite a bit of stuff from them. |
Originally Posted by Minidogger
(Post 4437650)
I also like the idea of not having to shell out $35 for a filter every 20K miles. By breathing better, I meant .... well it does, lol. It was mostly just something I could feel. It just seemed to run a little more even and felt strong after the change.... that said the old one was a bit dirty, but just looking at them, you can see that it is less restrictive. |
(Post 4437655)
Derek86,
Originally Posted by WayMotorWorks
(Post 4437317)
Since you just want a stock replacement filter I'd go with the Afe Dry filter https://www.waymotorworks.com/dry-pa...-cooper-s.html My second option would be the K&N filter https://www.waymotorworks.com/k-n-dr...-cooper-s.html I replaced it with a K&N filter...so far so good. I've ran K&N's on lots of vehicles, bikes, boats, etc, etc.....never had any issues with oil messing with the MAF sensors.....I think the problem comes from guys who wash them, and they over oil the crap out of them. |
On one hand -
Foam filters - Note, that this was a few years back... All tests were done by running two, back to back dyno runs to verify each. I watched first hand as a lightly oiled foam filter work fine to about 3500rpm (Yamaha 1000cc sport bike race engine), then loose power above that, by chocking off the inlet system. This was verified by running the engine without...filters on two dyno runs. Without changing ANYTHING...but the filters, K&N filters were installed. The power continued to climb all the way to the redline (11500rpm), with just a couple of HP loss from no filters, above 9800rpm. Cotton filters - In the past...I was not impressed by the cotton filter design. I talked to the K&N people at length about this on a couple of occasions. When you can "see direct sunlight" thru the filter...that is a bad thing for any "filtering" action...period. I have an EBR (Erik Buell Racing) 1190cc sport bike. It comes from the factory with a K&N (panel) filter. I've actually been impressed on how well that it actually DOES stop the fine dirt (as checked with a 10x glass and white cotton gloves). So...this filter has changed my mind on current cotton filters. As long as NO direct sun light can be seen thru a fresh filter, its "filtering" action, should be fine. Although not as good as a paper filter, the paper filters will also block airflow above given RPM's (depending on the brand). Mike |
Originally Posted by OCR
(Post 4439826)
On one hand -
Originally Posted by MrGrumpy
(Post 4439934)
This is good info |
